Boost vaccumm
Old Dec 9, 2010 | 10:07 PM
AtomicX's Avatar
Default Boost vaccumm
For some reason today my boost gauge is acting up (or so I think). Usually when cruising, not pressing the accelerator,
the gauge reads about 10InHG, now today I noticed that it reads at the very very bottom of the gauge, the needle points straight down.
What could be the reasoning behind this?
Old Dec 9, 2010 | 11:08 PM
Melted rings and broken valves, with heavily scored cylinder walls, in the worst case.
Old Dec 9, 2010 | 11:15 PM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
Mine at idle reads like 25-30HG, and when i am oin the interstate, mine is usually around 22hg at cruising speed, under boost it reads about 16 psi!!!
Old Dec 10, 2010 | 06:20 AM
daytonmvp23's Avatar
LOL ^Stocker finally starting to get your sense of humour
How about just a faulty vac line to the gauge first.
Old Dec 10, 2010 | 08:00 AM
AtomicX's Avatar
I looked, all my hoses looked good.
Old Dec 10, 2010 | 09:24 AM
Well what kind of gauge do you have? Is it mechanical electrical or digital? And the vac line hooks right to it correct? If it is mechanical hook a vacuum tester to it and ss f it moves the needle. If it does then you have a vac leak if your car is still running like it should.
Old Dec 10, 2010 | 10:16 AM
turbosocks's Avatar
most likely either a leak (that you didnt catch) or just a faulty gauge.. what is the vacuum at idle?
Old Dec 10, 2010 | 10:54 AM
AtomicX's Avatar
Uh, it points to the very bottom so I'm guessing thats 30InHG?
Old Dec 10, 2010 | 11:50 AM
Well lets ask the obvious question does the needle move at startup or does it just stay down?
