oil cooler
oil cooler
Okay, I think I've got the charge piping figured out from the last thread. Thanks all.
Now for routing the oil cooler. Would it be fine to run from the turbo to the cooler and back to the oil pan? Or should I sandwich plate it?
Now if I'm not mistaken, the sandwich plate goes to the pressure side. So where would I connect the oil cooler return to?
I guess basically, is there enough pressure from the turbo to be able to keep the oil circulating through the oil cooler? And, is that a viable option to run?
