Anyone ever had engine exploded from bad Tuning?
Old Oct 16, 2010 | 12:04 AM
TibbyTurbo's Avatar
Vehicle: 1998/Hyundai/Tiburon FX Turbo
Default Anyone ever had engine exploded from bad Tuning?
Have anyone ever experienced engine blow up because of bad tuning? What did you done wrong and what you should have done to have prevented it from happening, share your stories.
Old Oct 16, 2010 | 01:43 AM
tanc's Avatar
Vehicle: 1997 Tiburon
Yes.
What I did wrong....tuned using remote detc4 strapped to the engine.
It blew up. What I'd do next time is not use c4.
Old Oct 16, 2010 | 08:40 AM
SR Tech's Avatar
Vehicle: 2011 Tuscon
I have never seen one explode, would be interesting to see though. Might have to give that c4 a try if it worked for tanc, cause that guy is the tits.
I have seen plenty of detonated pistons, rods through blocks and pans!, valve heads embedded into piston crowns. I've taken heads off and found 3 # 10 bolts in the CC, from the intake, red rags stuffed in intake plenums. And most of these were caused by the owners choice of previous mechanic....how much do you trust yours? smile.gif
Old Oct 16, 2010 | 08:48 AM
blew a motor up from nitrous before
i shouldve taken it apart and took pics of the damage
but i was lazy
Old Oct 16, 2010 | 07:51 PM
My machine shop has a piston on the counter from one of their DIY customers. A brand-new $600 piston with low-friction coatings on the skirts, high-temp resistant coating on the crown. Big hole from a valve stem right through the crown. Zero miles, the timing was set wrong at initial build time. Doh.
Old Oct 18, 2010 | 07:09 AM
03tibe85's Avatar
Vehicle: 2003/Hyundai/Tiburon
I've seen a Delta engine shove a rod through the block due to bad tuning on Alpine's part. It was when they were street tuning their Delta Stage 2 Supercharger kit. AFR went lean, and kaboom.
Old Oct 21, 2010 | 12:40 AM
Denisst99's Avatar
my old engine... stock bottom end,ported head,cams, air ram super 60 turbo about 22-25 psi
bad batch of fuel (winter fuel has less octane)
pesky bmw driver and pig headed driver (me)..i heard it ping,but didn`t want the bimmer to go up front...
result, bimmer stayed behind, put i hurted #4 piston
actually the rod small end had some aluminium powder stuck to it and the inside of the turbine housing had been "ceramic coated" by the burning aluminium
i`ll try to dig up a pic of the piston we melt on our TAD dragster.. that one is is WAY nasty...
Old Oct 23, 2010 | 09:06 AM
TibbyTurbo's Avatar
QUOTE (Denisst99 @ Oct 21 2010, 01:40 AM)
Is this a stock high compression piston or low compression aftermarket what brand?
Old Oct 23, 2010 | 10:27 AM
Denisst99's Avatar
100% stock beta2 bottom end
decked block and shaved head so i would wild guess the compression ratio was around 10.7
Old Oct 27, 2010 | 11:05 AM
Denisst99's Avatar
more boost,,longuer warm up/burn out
