Oil Feed
Vehicle: 1998 Elantra
Oil Feed
i have a 1998 hyundai elantra im boosting, where can i get the oil feed from? i was looking into an oil filter sandwitch that has 2 outles coming out of it?
i pull my oil from the side of the head. if you use a sandwich plate i'm pretty sure you need a restrictor since the pressure there will be high. and unless you're running two turbos you only need one outlet, those two outlet plates are meant for oil coolers.
side of the head, on what side? got any pics? is there any tapping involved? thanks so much
yeah, drivers side front corner. theres a plug there stock but it was a pain to pull out, i ended up drilling out the center and it loosened up enough to pull out.
Turns out it's easier to machine an oil gallery from the end then put a cap in the end, than to cast an oil gallery in when the head is poured.
As posted above it should be 5.5 or 6mm. If your asking this question you should really reconsider boosting your car. Have fun with NA mods until you build mechanic skills. Just my honest opinion.
