Twin Scroll Turbo Systems
Vehicle: 2005 Tibby
Trying to wrap my head around this concept and understand how twin scrolls work versus traditional single scroll turbos. I found this article which does a somewhat decent explanation of it, but I want to learn more and see what advantages it has over single scrolls.
http://www.modified.com/tech/modp-0906-twi...sign/index.html
Twin-scroll turbo system design addresses many of the shortcomings of single-scroll turbo systems by separating those cylinders whose exhaust gas pulses interfere with each other. Similar in concept to pairing cylinders on race headers for normally aspirated engines, twin-scroll design pairs cylinders to one side of the turbine inlet such that the kinetic energy from the exhaust gases is recovered more efficiently by the turbine. For example, if a four-cylinder engine’s firing sequence is 1-3-4-2, cylinder 1 is ending its expansion stroke and opening its exhaust valves while cylinder 2 still has its exhaust valves open (while in its overlap period, where both the intake and exhaust valves are partially open at the same time). In a single-scroll or undivided manifold, the exhaust gas pressure pulse from cylinder 1 is therefore going to interfere with cylinder 2’s ability to expel its exhaust gases, rather than delivering it undisturbed to the turbo’s turbine the way a twin-scroll system allows.
The result of the superior scavenging effect from a twin-scroll design is better pressure distribution in the exhaust ports and more efficient delivery of exhaust gas energy to the turbocharger’s turbine. This in turn allows greater valve overlap, resulting in an improved quality and quantity of the air charge entering each cylinder. In fact, with more valve overlap, the scavenging effect of the exhaust flow can literally draw more air in on the intake side while drawing out the last of the low-pressure exhaust gases, helping pack each cylinder with a denser and purer air charge. And as we all know, a denser and purer air charge means stronger combustion and more power, and more power is good!
But the benefits of twin-scroll design don’t end there. With its greater volumetric efficiency and stronger scavenging effect, higher ignition delay can be used, which helps keep peak temperature in the cylinders down. Since cooler cylinder temperatures and lower exhaust gas temperatures allows for a leaner air/fuel ratio, twin-scroll turbo design has been shown to increase turbine efficiency by 7-8 percent and result in fuel efficiency improvements as high as 5 percent.
Vehicle: 2003/Hyundai/Tiburon
Think of a twin-scroll setup as supercharging the turbocharger. LOL
By pairing certain cylinders together the alternating exhaust pulses help to pull exhaust gas out of the cylinder (scavenging) as well as lower backpressure. The pulses are no longer competing for space in the turbine which greatly aids spool time.
Its like taking four trains and having them merge all at once on the same track vs having them all be in the same line on two different tracks, if that makes any sense.
Twin scroll flow ---------- > Turbine
Non twin scroll
turbine
Non twin scroll
turbine
Vehicle: 2002 hyundai accent
its the same concept as unequal length headers. each pipe is a different length so that the exhaust gases enter the collector ,in the concept of, "in a single file line" instead of "in a funnel". thinking of it as kids in lunch line at school.
