injector questions
Vehicle: 1999 hyundai tiburon
injector questions
hey guys i found some cheap injectors from a volvo 760 turbo. its a 32lb bosch injector i am wondering if anyone know's if it will plug into my fuel rail or if id have to modify it at all. the manufactor part number is 0280150804 they said its for a volvo 740 760 780 and a 940. The car i want to put them in is a 99 tiburon. Thanks
Vehicle: 1997 Tiburon
They might fit but I'm not sure if anyone has ever used those or has had them fitted/measured.
Those are only 2.7 ohm which is low-impedance we require high-impedance injectors if your running a piggyback. They are only 30lb injectors.
I got some ford racing 42lb injectors that are direct fit high impedance with only 1000 miles on them. PM me if you'd want those instead.
I am running volvo injectors. Not sure on the exact part number but the ones I used are 32# and are direct fit plug and play!
Note: you will need at least a piggy back to tune them! The stock ECU by itself will not tune them, as I am sure you are aware.
