- Check Engine Codes
- upgrade stock battery 05 tib-v6-2.7
- Are hyundai vehicle parts interchangeable?
- screeching fan belt noise
- need advice for xg350l
- Crankshaft
- Hyundai FAQ - Everything You Ever Wanted To Know (mostly Tib Info)
- Odometer Cable
- N/A Horsepower gain help!
- Kurplunk...found the niose but ....?'s
- having a few problems mainly electronic
- plug wire broke help!
- kinda foamy oil on inside of oil cap
- High/Fast Idle after turbo....HELP
- molding body kit....
- Help removing rotor
- Puddle Of Oil
- Need help!!!!
- door locks with alarm
- how do u take off the back seat?
- help with cai
- help with cai
- ignition help again
- fuel guage problem
- Hydraulic Lash adjuster
- Acceleration problem!
- Chain noise
- clutch sliping
- kurplunk when braking heavy and accelerating???
- what could cause ....
- oil leaking out of valve cover?
- I think I've screwed up my car big time!!!
- door lock problem
- a/t problem on hills?
- Electrical probs
- Weird noise
- Engine Stand Bolts
- eibach springs ?
- I need HELP...bad!!!
- Bigger Fuel Pump causing car 2 stumble when cold?
- Electrical Problems and Engine Woes
- Help with shipping
- Door chime???
- AC wont work
- wheel bearing
- SUSPENSION NOISE: PLEASE (RANDOM?)
- crunching noise?
- car no starty??
- aceleration and a 5th gear switch?
- Wierd ... SCARY noise
- Desperately Need Help...
- fender box
- MSD Dis-2 Trouble
- HELP! 03 vs 99-02 PARTS HELP!
- Technician 4 hire
- oil filter thread
- Address to mail Hyundai Payment
- Muffler Help.
- People with clutch experiance
- AC compressor....
- another fuel filter problem
- exhaust dilemma...Random.plz help
- Auto trouble*Update*
- A/C and tranny don't mix......
- Friggin Stupid Crap damnit Rear Discs!
- What is this noise?
- 98 brakes
- Steering Wheel Shakes
- Splash Guard?
- A/F ratio problem ?
- help with an auto tranny....
- Wierd Idle today....!?
- another idle problem :(
- 2.25 or 2.5....i need help
- Ack! I screwed up.
- Fuel Pump Problems
- INDIGLO HELP! TACH PROBLEM
- how to intall 4 pt. harness belt.
- shifting VERY difficult
- Window Switch Circuit Board
- Idle problem
- Intercooler Sensor
- Need help with pistons
- Help!!! Guage Cluster Lighting
- My car's brakes are puzzling me...
- Seatbelts
- Transaxle Seal failed!
- new owner of used elantra
- Trunk light in cluster
- Quick Question
- Header/o2 issue! Cel code retrieved
- Need Help!! EXPERT ADVICE!
- brake pedal to floor!!!
- Tibby won't start: No Fuel flow, no spark
- Exhaust Help
- rotors and wheel bearings..how hard to replace?
- TPS blues
- web site
- still got tick
- O2 sensor check engine light
- Revision A... Evolved!!!
- Car won't Idle!
- Parts from Japan... Advice pls
- Vibration - not tires
- weird suspension noise
- LC intake help
- clueless
- help got tick
- Another Exhaust question..help
- Back Brakes
- Oil Consumption
- blown damper
- Hmm... Can't figure out this problem..
- ignition problems??
- my car still hiccups,PLEASE HELP!!!!(got it fixed)Thanks
- Tranny mount problems
- timing belt (need help fast)
- check engine light from headers?
- I need Hyundai Shop Manual...or?
- Attempted theft!
- GL4 and GL5 gear oil *Help?*
- One-time no-start
- engine "hiccup"
- Changing transmission Fluid.*quick Q*
- misfire and CEL
- Guage readings
- How do I mount the stick shifter???
- Wiring diagram with MAP?
- Need help...please!!
- Absolute Mayhem!!!
- Fuel Pressure Sensor 97 vs. 00
- HELP ABOUT THE REVISION A
- speedometer cable
- wanna help get answers from greddy?
- Help! Leaky bolt on tranny!
- Fog lamps 4 a 99 Accent Where???
- well, F??K ME!!!
- P1123 CEL
- Hood getting stiff?
- overdrive re-wire problem
- Is this normal?
- 1.6 beta 1 engine wiring diagram
- chain noise
- Ack! Cracked Header!!!
- HELP!! New CEL!!!
- guages
- Stereo install gone bad!
- Stupid O2 Sensor
- changing oil
- tranny prob
- Lowest Eibach prices...
- HELP! Sparkplug wire to Ignition coil ???
- WHERE IS THE IGNITION WIRE!?!?!?!
- Red, Random... anyone. HELP!!!!!!!!!!!!
- Help!! no HEAT!!! brrrrrr.
- Engine dies after starting?
- Quick fog light help!!
- engine noise
- FORUM ANNOUNCEMENT
- help with exhaust questions?
- O2 Sensor Output voltage STUCK!?
- Rebuilding the engine
- Cable adjustment?
- Taking off alternator
- oil in plug holes
- O2 sensor/fuel problems
- OBD-2 QUESTION!!!!!!
- Engine dismantlement :\\ Help Experts
- Front 6.5 speaker for tiburon
- installed BBTB and now have CEL
- Torque specs?
- Oil pan removal
- Glow Gauges
- car boging
- reving to high or something
- Posi or one leg?
- F*$kin fuel filter
- Car won't start
- all fixed then not
- Intake help...quick
- HEADER INSTALL ASAP!!!!!!!!!
- Rushing Sounds
- 'Loose' in the front end
- Gasket Replacement
- what do they do at 7500 mille checkup???
- removing/installing new wipers
- Passenger Window Problem
- what should i do
- Flashing CEL
- Engine hiccup?
- adjusting headlights
- OBX Shifter Slop
- Engine not starting
- Engine Overheating.
- wheels n hub adapters
- Radio Problem
- Daytime Running lamps???
- Wierd CEL CODE!
- HELP Fuel Filter removal
- please help!!!
- air bag lgiht
- Need wiring diagram
- CEL
- Window tint in WINTER???
- reverse problem
- stupid question!!!!!!
- Help
- weird pseudo-hole exaust-noise
- Seat Belts
- dash lights!!
- god damn my car lol
- sticking steering wheel!!!
- Tib 2000 Dashboard
- Posting Images... help required.
- Smoke??
- engine stalled, now acting weird
- Help Gasket Advice?
- Possible Powers gains with...
- HELP&Can I get some advice??
- weird brake issues
- My tib Might just be possessed-ALARM-
- Not really a help but an Advice ?
- idel problem
- Insurance Rates
- engine problem
- Beta Swap- engine from Australia
- hunting idle and check engine light on when first start
- Running lights and alarm lights won't work.
- s-afc air flow % question
- Whats wrong with my Engine?
- Oil change at 70,000 question
- White Guage instalation
- Goofy Idle
- ignition coil burnt out
- a/f meter question...
- problem with blinkers
- Battery dead
- Hyundai's 3.5L engine, in a new TIBURON???
- Rumbles at idle
- tps and s-afc problem
- Totally OFF topic!
- are the sealtbelt anchors the same for 97-99 and 00-01
- my brake light seems to be shorting out! 00 tib
- my window rolls up too far! 00 tib
- rpms only half?
- Another question
- Question
- dash vibrating
