tps and s-afc problem
Old Oct 31, 2002 | 11:52 PM
turbulence's Avatar
Default tps and s-afc problem
my s-afc only reads, that at wot, i'm at around 94-95% throttle. i push the pedal as far as i can, but i just won't read any higher. i'm thinking that it might have something to do with my bbtb and the tps reacting differently to it for some odd reason. any suggestions?
Old Nov 1, 2002 | 04:14 AM
Nope, that is 100% normal. Some Tibbies the TPS reads 100% as only 86% at WOT. I've verified that the throttle butterly is at a 100% horizonal position, but the TPS only registers it as 86%.
if yours reads in the 90's, I'd say be happy with that.
Old Nov 1, 2002 | 06:18 AM
turbulence's Avatar
WOOHOO, I'M AT 100 POSTS. thanks, random. i was thinking that this might cause a problem if i got like the zex nitrous kit because it sprays at 100% throttle. i would imagine that you could change that point, but i just didn't know.
Old Nov 1, 2002 | 06:37 AM
Jon's Avatar
Jon
Nothing to do with the post i just have to sat nice sig mate great when that happens isnt it.
Old Nov 3, 2002 | 06:09 PM
I know the Zex kit worked on the car that only registered 86%...so it should work with no problems on your car with 90something%
