Fuel Pump Problems
Old Mar 12, 2003 | 06:14 PM
FlyRyde's Avatar
Default Fuel Pump Problems
I cant figure out why but when I connect the plugs from the harness up nothing happens. But when I run a wire from the battery the pumps works great. I need to figure this out so I can drive the car. If not it's goin to a mechanic.
Old Mar 13, 2003 | 01:06 AM
Did you ever check your Girlfriends car? Does her fuel pump get 6.5V at startup or 12V?
If she's getting 12V, it's got to be the fuel pump relay circuit.
I emailed you the plug connectors and the wiring diagrams.
Old Mar 15, 2003 | 03:20 AM
After spending a nite working on wiring. It now runs. We took it for a short test drive, but there is still lots to be done before it's "streetable"
Old Mar 15, 2003 | 06:44 AM
FlyRyde's Avatar
It took me like 30 minutes to fix the intake manifold problem. Now it's perfect and I installed the AEM intake ("you cant use that intake, you have a REV A") It sounds soooooooooo BAD, not bad but fvcking AWESOME!!!
And she purrs like a kitten at idle now. Only thing I notice is a high pitched noise. Maybe even a hiss??? I think its the exhaust manifold, but fvck that thing, I'll have headers on my doorstep soon if this CNK GB gets goin.
Old Mar 18, 2003 | 06:34 AM
FlyRyde's Avatar
Yesterday I was at a friends house, and when I went to leave I put the car in reverse started to move and then it stalled. My buddy laughed at me. Then I did the same thing again... and it stalled again. Then it wouldnt start after that. I checked the "back door" to the fuel pump and it works when given power. I know all the connections are still good. Why would the fuel pump just decide not to turn on after I had been driving around for 2 days after we fixed the problem. Luckily this time I have it in the shop so I don't have to figure it out but still WTF is goin on with that pump????????????
Old Mar 18, 2003 | 06:41 AM
how about your "wiring" job to the pump?
Old Mar 18, 2003 | 07:35 AM
Shadohh's Avatar
Fuel pump will shut off. If it is unable to keep pressure in the lines. now. trying to use it 3 times. should cause enough loss to be an obvious spill of gas.
Old Mar 18, 2003 | 01:28 PM
FlyRyde's Avatar
I wonder what happened to piss off the fuel pump like that though. Everything was fine. I took the car around the block, parked came back in 10 minutes and... nothing?
Old Mar 20, 2003 | 02:41 AM
FlyRyde's Avatar
The shop it's at said that it must have "found a ground, then it overloaded and lost that ground" I think me and Random switched the order of wires to be different than both the 1st and 2nd gen tibbies. I stopped by westways yesterday and looked at the fuel pump and it was a lil diff. It had the connector in a diff position and therefore is not "identical" with the first gens. What do you think.
Old Mar 20, 2003 | 03:55 AM
The wiring diagram's were different between the 2, but the connectors were the same. I think they just switched 2 ground.
However the ground we had was working....I've never heard of "burning out a ground"....
