Door chime???
Old Apr 11, 2003 | 01:03 PM
biomknx's Avatar
Default Door chime???
How in the hell do u shut off the door chime without removing the harness from the side of the door, I did that and then I lost the chime for when I leave my lights on, also the chime for when the key is in the ignition drives me nuts. How do u get rid of it?? And yes I did use the search b4 I posted, nothing came up.
Old Apr 11, 2003 | 01:26 PM
hyundai jvx's Avatar
Vehicle: 2005 MINI Cooper S
I removed the thingee from the door. I haven't had any problems for the past 2 years. There is a way to get rid of it without doing what I did... I'll look for it...
Old Apr 11, 2003 | 01:39 PM
I found an OLD post asking the same question, answer thanks to Tunez...
Yes it can be killed!!! It is a little black box similar to a relay under the dash to the right of the steering wheel. If you lay in the floor and look up it is closer to the radio. Just start feeling the black relay looking things. When you feel the one that is clicking thats is it, unplug it a there ya go.
Old Apr 11, 2003 | 09:11 PM
biomknx's Avatar
thanks alot Zaibatsu
Old Apr 12, 2003 | 02:29 AM
Sir Moof's Avatar
My chime doesn't work when i leave my lights on with the door open.
That's why i always forget, and my battery goes dead suicide
Old Apr 12, 2003 | 04:21 AM
AllBlackTibby's Avatar
Ah thanks, I just went down and unplugged mine.
Old Apr 13, 2003 | 01:12 AM
FlyRyde's Avatar
I cant believe no body posted who knew how to help. If you get on your back under the steering wheel and look up using a lil flashlight. There is a metal, unpainted shield (of sorts) over the column. That is where the "ding box" is at. You can find the clip that holds it in if you follow the wires from the box. I'll take pics and show you how. Dont even worry about the door.
You do want your lights when the door is open and not the ding right.
Old Apr 13, 2003 | 01:22 PM
Umm... I thought I did. 3rd post down from the top. poke
Old Apr 13, 2003 | 03:24 PM
Shadohh's Avatar
ITs two wires atop of the Key ignition.
Take off the two plastic things holding the steer column.
remove the RED coated power wire from the top of the Key ignition. Thats is were the bell chime comes from.
Old Apr 14, 2003 | 12:19 AM
biomknx's Avatar
How would u remove the chime from the lights when the door is open when they are on?? Is there a way or is it that little black box under the dash??
