Chain noise
Old Apr 29, 2003 | 10:19 PM
NUTTANICK PREMBOON's Avatar
Default Chain noise
Has any one got the problem with chain noise even your car is under 40,000-50,000 km.
Old Apr 29, 2003 | 10:39 PM
lantraluvr's Avatar
Vehicle: 1999 Elantra
What does chain noise sound like?
Old Apr 29, 2003 | 10:50 PM
turbulence's Avatar
are you talking about the noise from under the timing belt cover? webtech has a tsb about that.
Old Apr 29, 2003 | 11:17 PM
It's sound like chain is lose.
Old Apr 29, 2003 | 11:26 PM
lantraluvr's Avatar
I have no clue on what a loose chain sounds like.
Old Apr 30, 2003 | 12:54 AM
Sir Moof's Avatar
I have that sound. I figure it's the lifters.
Old Apr 30, 2003 | 03:17 AM
Sir Moof:
We don't have lifters. No pushrods.
What part of the engine does the noise come from? When do you hear it?
We need more information to figure out what is going on.
Old Apr 30, 2003 | 05:10 AM
The sound come from under valve cover where the chain is and I'm sure not the hydraulic lash adjuster because I've had checked them.
Old Apr 30, 2003 | 09:13 AM
turbulence's Avatar
hmm. did the 97 1.6L betas have the same cam gear setup as the newer betas do? maybe the cam chain is the cause? dunno
Old Apr 30, 2003 | 07:31 PM
You can always replace the intake cam drive chain. But I'd reccomend you remove the valve cover and just look at it/examine it. You should be able to visually inspect it to see if it is streched and is showing slack and needing replacement. Hyundai doesn't have any "reccomended" replacement interval for that chain. I can't really see how you could stress it enough to strech it, but I guess it's possible. Only a visual inspection will tell.
Take the 14 bolts off the valve cover and give it a peek.
