ignition help again
Old May 3, 2003 | 01:20 PM
Tony Montana's Avatar
Default ignition help again
OK so we have done this once before and I got nowhere
MSD tech told me to measure vith a voltometer to find out which is the coil +, this got me nowhere. this just got more me more confused.
look here does anyone know know what wires are what? Thats all I need to know. there are 3 wires there, Please help me to identify which one is Coil +, Coil -, and coil-. This is killing me. The dealership is not much help either, they were suposed to get back to me a week ago?
Colour ID would greatly help.
anyone with an MSD dis II? Can you help???
[ May 03, 2003, 08:22 PM: Message edited by: Tony Montana ]
Old May 3, 2003 | 02:04 PM
Shadohh's Avatar
for the 99 tiburon
pin 1 is for coil two fire command
pin 2 is for coil one fire command
ping 3 is 12 volt
The bracket is the ground.
http://www.hmaservice.com/webtech/iindex.a...1133#_394881133
note: 2000-2001 have pin 1 and 3 opposite
Old May 4, 2003 | 03:26 AM
Looking at the MSD instructions, The wires should be a Coil -, coil -, and a coil+. Is it safe to read that as pin 3 is my coil+ ( the black wire with white stripe if I remember correctly?)
[ May 04, 2003, 10:27 AM: Message edited by: Tony Montana ]
Old May 4, 2003 | 07:40 AM
Shadohh's Avatar
hyundai never follows color code.
Just look att he connector and use the right wire to the right pin.
Since there is only one 12 volt that is obviously the coil +
and the other two are grounds for the coil - and coil -
Old May 4, 2003 | 10:49 AM
Thanks, Im going to give it a try.. will let you know.
Old May 4, 2003 | 03:03 PM
Moving to HELP forum. poke
