my window rolls up too far! 00 tib
Old Oct 31, 2002 | 12:02 AM
ONLY1DB's Avatar
Default my window rolls up too far! 00 tib
whenever i put the window up and then step out on the passenger side and shut the door...the glass is too high and does not fit under the molding on the top of the window seal. how can i fix it??? shave the glass down??? i tried putting insulation inbetween the rubber gasket and where the window comes up to keep it from going to far...but it doesnt work all the time...anybody?
Old Oct 31, 2002 | 01:12 AM
KayJai's Avatar
Your guides / tracks are out of wack.
And they are a bitch to adjust. You can check HMA to see where the adjustments are inside the door and try to do it your self.
Trust me, from getting my driver's side window broken 3 times from idiots breaking into the Tib, it's not in the OEM position anymore. But pretty damn close, since J@WS01 (Hyundai Tech.) did the best adjustment he could for me.
If you feel up to it, check HMA for adjustments, but if not, take it to the dealer.
Old Oct 31, 2002 | 02:08 AM
Jaime's Avatar
Hey aI just got a problem reccently I have a 2002 Kia Spectra GSX which has power windows, and when I roll the window up it wiggels waggally..My dealer Said it was my tint and they want cover it under warranty....Which I know its not the tint....But what do some of you think it is....
Old Nov 1, 2002 | 12:56 AM
ONLY1DB's Avatar
that sucks...well i will have to see if i can adjust it!! well if it screwed up now...i really cant do too much harm right? *L* wink
Old Nov 1, 2002 | 02:23 AM
hyundai jvx's Avatar
Vehicle: 2005 MINI Cooper S
I'd cry warranty. Hell, I run out of gas and tell them it's under warranty. 10 years, 100,000 miles, they will pay.
Someone down here has the same problem, I think... Mach 5? hrmm..
Old Nov 1, 2002 | 08:35 PM
ONLY1DB's Avatar
if i was still under the bumber to bumber i would have done that already...however i have 87000 on it and i dont think that they will cover it!
