View Full Version : HELP Forum
- 06 Sonata: Sourcing Replacement Snap Rings for Compressor
- Wheel fitment for coupe.
- 06 sonata wandering while driving
- How do you disable annoying door ding?? 2002 hyundai accent
- Help….
- rear windows not working
- Won't Crank, But this seems a little different.
- 2010 iload engine
- Windscreen washers
- Doors that are interchangeable
- Veloster not starting
- SUPER DUPER annoying MAF high reading
- 2007 Accent wont start sometimes, not the battery
- Steering rack J2 Elantra wagon
- Melted Connectors at I/P Junction Box 05 Tucson
- Window Regulator 2014ish Elantra
- Stop lights not working - But swittch is OK
- Third gear grinding
- Clunking on bumps - Not Endlinks
- Engine stops intermittently. Sometimes cranks, but won't start. P0335 Crankshaft Position Sensor code set.
- 2l beta swap in accent 2004
- startup issue
- 97 coupe jerky throttle loss of power
- Intermittent loss of power/electic - 2004 Hyundai Elantra
- valve float?
- Clicking/Ticking Under Acceleration
- HELP ME PLEASE CLUTCH/GEAR ISSUE :( - newbie
- restoring exterior cowl
- Stuck fuel gauge
- Cylinder no.2 misfire CEL
- Front Impact Sensor Wiring
- Random's Non-Start Troubleshooting Advice
- Install backup camera - 2010 - 2014 Tucson
- Cooling fan not coming on
- 2001 Tiburon Inner Fender
- No Crank No Start
- Quick question about small part
- x3 hyundai accent 1997
- Removing instrument panel
- brake lights
- what oil viscosity is used for my 01 tiburon(rd model
- got a tricky lil SOB
- O2 Sensor Harness Melted
- Engine not stopping with ignition off
- Bogging
- Sound when pressing brakes
- head gasket? issue
- Weird electrical gremlin
- 2004 Sana Fe Fuel Tank replacemetn
- Radiator wiring help needed
- Crankshaft Pulley Bolt Tool for 2001 Hyundai Accent 1.6L
- ECU
- I NEED HELP!!!
- relays
- Impossibly Jerky Throttle
- 2001 Tiburon Won't start
- Is there something missing??
- road noise..or other?
- wont Start after trans swap
- Weird starting issues
- Removing heavy duty cleaner
- Starter/Transmission mesh nightmare
- Rear Suspension Clunking
- The p0102 DTC
- Engine swap wiring troubleshoot
- What to change with timing belt
- What type of rim is this? (Pic included)
- Megasquirt ECU Help!
- Camshaft journal bolt tightening order?
- Half of my ignition system is union labor
- Power window = no power?
- stripped screw
- Fuel air mixture problem
- Car hesitation, engine skipping
- Misfires and an intermittent Check Engine Light
- Electrical Issue?
- Having electrical problems
- wipers dont work on delay... help
- Wierd electrical issue
- Think i lost third gear
- Engine Coolant Temp Sensor Stuck!! Help!!
- Starting issues
- How do you adjust the hood hinges to get it to fit properly after a minor accident involving a new hood if it doesn't fit correctly
- 1.8 cam install gone wrong.
- RD1 Tib Running Rich
- weird wiper linkage / motor issues
- problems alcohol won't solve
- power steering isn't sufficient
- Cruise control not working
- Car wont start after replacing coil pack harness
- P1124 Code
- How do I undo these bolts?
- rear suspensino making grinding noise after brake change
- need Hyundai transmission?
- Where to get Service Manuals
- clutch wont engage
- Excel is dead on the side of the freeway
- Still C.E.L.
- Hard start after re-fueling
- Hi temp for brakes
- Tib dies at idle
- CEL help
- MY BRAKE LIGHTS WONT TURN OFF
- Hood fits out of alignment
- 98 elantra manual tranny leak help!
- installing H4 HID's right now, have a few quick questions!
- is this ecu compatible to the rd1?
- Trans Noise
- pics to profile
- CEL on, Idling at 3k RPM
- Heater Core
- Unstable idle, speed needle pinging, car won't start
- engine removal
- Oil flush with ATF help
- Towing a car
- Car dying while in reverse
- I hate to ask...
- How best to use webtech?
- Adjustments Needed for "New" Parts
- pulling off stuck drums
- 2000 elantra
- Running like crap after P&P cylinder head...
- iacv and tps problem
- help! broke a screw in half!
- strange noise coming from rear
- Loosing coolant...
- intermitant issue w/ bog/surge and misfire
- wiper linkage bushing
- Emanage blue 2000 tiburon
- oxygen sensor wiring problems
- Problem after GSX fuel pump install?!?
- OPINIONS/LEGAL ADVIE HELP!
- Underdrive Pulley to Replace Warped Stock Pulley?
- Engine help
- Problem after walbro 255 install
- Rear brake caliper tiburon Questions
- elantra 2002 overheating
- Wiring problem?
- Chassis Wiring Diagram for recent Accent
- How to remove rust stuck bolts or screws
- Inner Tie Rod Replacement!
- Shifter Bushing Removal Not Gone Well
- Ignition Coil
- weird electrical problem
- The lights giving me a seizure
- HELP Ignition switch wiring mess
- Stripping TPS Screws
- A Couple General Questions
- ECM and Fuel Pump fuse keeps blowing!
- rich idle
- jacking points
- Tiburon Overheated, Need Advice Please
- Don't know what to do
- Oil Leak or Something Else? Helpp 2000 Tiburon
- RD Tib Fan Trouble
- Heat problem
- CEL is on again ughhh
- Tiburon overheating - help me diagnose
- Oil pressure issues (4G63)
- Car Cranks but No Start
- Differential Problems?
- intermittent starting problem
- Sparkplug soaked in OIL?
- running rich cel code?
- Wandering Rear End
- Oil become gooey?
- Battery discharging overnight
- heater is not working
- STEAm coming from Air intake!!
- RADIO,TURN SIGNALS,AND HAZARDS DONT WORK NEED HELP
- Crankshaft postion sensor, where is it?
- Transmission noise
- 1156 to 1157 light bulb socket swap
- ECU Reading Project
- Smog Rejections w/o CEL
- 2000 Tiburon
- 1.8L Water pump for 96-01, or 2.0 Pump for 03+?
- Loud squeeking
- Your help is needed.
- frustrated and pissed rant
- car bogs down under throttle on rd1
- hood cable broken! how do i open the hood from the outside?
- Car will roll start, everything works then dies after 1-2 minutes.
- No Start / No fuel
- Passenger window stays down
- Help me identify this lonely connector...
- PO103 and PO136 come up
- Fuel line leak
- Check Engine Light?
- Extra bolt after clutch install??
- Right-Rear suspension squeaking
- speedo not working on rd1
- Temp reading
- Cars rear end wanders?
- cel, no clue what to do
- Generator Front Terminal Malfuction
- Oil Leak - 03 Elantra
- Flashing lights after timing belt change.
- Code question
- Car alarm..
- Crank shaft sensor???
- Moisture & condensation in headlight assembly
- Reverse lights not working
- 2002 1.5L sohc Tear down
- New problem
- The Car is "Hiccupping"
- Funny dash light
- Problem starting
- air flow meter unplugged
- MAF or TPS
- Intake Backfire
- question: wheel spacers + rubbing
- Shaking-ish?
- Car Hesitates
- Squealing when car is started?
- Sparks flying everywhere!
- Cabin air filter
- turbo problem
- Hydraulic Lash Adjuster
- Help
- Power steering gets weak?
- Will accessory gauges in deluxe Tiburon work in base model
- wind whistle on highway
- where is the canister
- Friend Needs Help...!!!
- Weird Oil Capacity Issue
- Information on the Moss Magnuson Warranty Act
- Ticking?
- beta swap Died? Help!!!!!
- Hyundai Shop Manual 2000-2002
- fans
- Added a few more Tech Tutorials
- After 1 month idle 2001 accent won't start
- RPM drop
- P1128 code hint/fix
- Head light spring clip
- Rattle/Knock
- Florida peeps!...my services are now available.
- Loud screeching noise
- Gas gauge problem
- 02 Sensor
- steering wheel assembly
- Oil catch can install
- turn signals/hazards no workie.
- Speaker wire Colours?
- Engine lights on
- "Grinding" into reverse?
- Washer Pump
- Heater blower not working
- Problems with my Moms Sonata
