Engine help
Old Aug 2, 2011 | 11:45 AM
bms6503's Avatar
Vehicle: 2001/Hyuandai/Tiburon
Default Engine help
my 2001 rd coupe broke down! it just syopped. I got it home and ran a battery, alternator, and starter test all checked out fine. its fine on oil, so i thought to check the fuel pump, no it was good too. I proceeded to remove the timing belt cover and valve cover gasket, both are fine! Any ideas gus? im lost
Old Aug 2, 2011 | 11:52 AM
What happens when you turn the key?
Video, or at least text of the symptoms would help
Old Aug 2, 2011 | 11:57 AM
Did it stop running while driving? What (exactly) happens when you turn the key? Does it click? Does the engine turn over but not fire? Were there any odd noises, smells, or other occurances before or during the initial breakdown?
Old Aug 2, 2011 | 03:35 PM
Regit's Avatar
Vehicle: 2000 tib
^ ya..Need more info.
Old Aug 3, 2011 | 07:37 AM
if it just cut off while you were driving and its a crank no start. then i would guess cmp or ckp sensors. i've had both go bad on 2 diffrent cars that had that same symptom.
