weird wiper linkage / motor issues
Old Nov 18, 2012 | 10:43 PM
merv112's Avatar
Vehicle: 1998 Hyundai Tiburon
Default weird wiper linkage / motor issues
Hey folks,
The windshield wiper linkage rusted out in my '98 tib, I replaced it with one I found at a boneyard in pristine condition, and I went ahead and replaced the motor while I was at it. Worked great for about a week.
Now, the motor won't function unless I dramatically loose the sole nut holding the linkage onto the motor stem. If I tighten it down too tight, the motor won't move at all, but if I loosen it to the point where it does work, it'll swipe the wipers 4-5x, then the bolt works itself so loose it quits working that way too.
Did my brand new pump die? Did I accidentally bind up the linkage? If I disconnect the linkage from the motor, I can work it with my hand manually, and watch the wiper studs move back and forth, so I don't think it's a binding issue (right?), but the motor is also brand new, so I'm not sure it's at fault either.
Any thoughts greatly appreciated.
Old Nov 19, 2012 | 10:01 PM
Use red loctite on the bolt in the "works but eventually falls apart" position?
Old Nov 19, 2012 | 10:20 PM
wheel_of_steel's Avatar
Perhaps you're missing a washer between the nut and the motor arm?
Old Nov 21, 2012 | 12:10 AM
merv112's Avatar
is there supposed to be a washer there? that's what I was thinking too, the service manual shows there being a washer there, but on my original assembly, and the replacement assembly, there wasn't one. I was thinking about adding one.
And I tried loctite, still vibrated/worked it's way loose, surprisingly.
