RADIO,TURN SIGNALS,AND HAZARDS DONT WORK NEED HELP
Old Nov 23, 2010 | 05:31 PM
Conho's Avatar
Vehicle: 2004 Hyundai Accent
Default RADIO,TURN SIGNALS,AND HAZARDS DONT WORK NEED HELP
Everything worked before i messed with anything. I was putting in a radio for a buddy of mine and i guess i tripped some fuses off......at first the clock went out, ac went out, hazards went out and turn signals went out, and radio wont work...................i replaced a fuse under the hood and under the dash fixed the clock and ac prob but im still stuck with the other probs i checked almost all the fuses and NOTHING anyone got ideas...................." 2004 accent"
ANYONE GOT IDEAS THANKS !!!!!!!!!!!!
Old Nov 23, 2010 | 06:10 PM
IIt's a fuse.80% sure. On the tib, the radio, sunroof, and I think right side are linked together to a 10 amp fuse
Old Nov 23, 2010 | 06:25 PM
Conho's Avatar
im pretty sure its a fuse aswell on a 04 accent.......what fuse would cause all of that to fail ?!
Old Nov 23, 2010 | 08:49 PM
under the hood
drivers side fuse box
IIRC its the 10 amp fuse on the right side of the 2 rows of normal fuses, toward the bottom
Old Nov 24, 2010 | 07:18 AM
StrikeEagle's Avatar
Yes yes, it's a fuse, blah blah blah.
More importantly, it sounds like you have a short somewhere. Possibly a loose wire from your radio install or a badly connected wire. If you replace the fuse and it works, great. If it breaks again just after you install a new one, then you have a shorted wire.
