Shaking-ish?
Vehicle: 2003 Hyundai Accent
When I'm at idle out of gear every now and again the engine............rocks?........... It feels like every couple of seconds someone lightly leans against the drivers side of the car then gets right back up. Any ideas what might be causing this?
BTW: It seens to happen more when the engine is hot, but that could be my imagination.
Have you ever had it do it with the hood up so that you could see what the engine does?
With the transverse mounting if the engine rocks the movement should be more or less front to back, not generally side to side. Maybe you have a loose/broken/worn out transmission mount?
QUOTE(187sks @ Aug 25 2009, 02:18 AM)
Not yet, so far everytime I've noticed it I've been on the road working, and it doesn't do it all the time.
QUOTE(Whiplash @ Aug 25 2009, 10:18 AM)
Is the car automatic or 5spd? Does it rock more when it is in gear? Next time you notice it, but it in neutral and see if it gets better or worse.
5 speed and it only does it in idle neutral the smallest amount of gas and it stops shaking. I looked the other day and it just feels like it's side to side in the car, the engine shakes front to back a little, but the engine mounts I could see (I saw 4, I dont think there are any more) looked fine.
QUOTE(187sks @ Aug 30 2009, 08:56 PM)
How low is your idle? Maybe you're idling too low...
It's a spot below 1000, I'd say 825-900 but that's where it's always been.
