Ticking?
Vehicle: 2003 Hyundai Accent
I've read a few ticking posts here, but mine's a little different.
When I start the car in cold to slightly chilly I get a ticking that speeds up with the RPM's, but stops around 3500-4000 RPMs. Or when it's really hot it's very loud when I start and doesn't stop till about 4000-4500 RPMs. Both way's I have to rev sharply while out of gear to stop it, and it doesn't usually start until after the car has been sitting a while (Mostly overnight).
Is it something I need to worry about.
BTW: I always change my oil somewhere between every 2500 mi to 3250. Depending on where the weekend falls.
What oil filters are you running?
It's oil starvation to your HLA's. The reason free revving your engine helps is because it ups the oil pressure enough to fully inflate the HLA's.
QUOTE(187sks @ Apr 21 2009, 10:45 PM)
You know I'd remember until you asked. It's the common orange w/ black grip thats sold everywhere.
What's best?
You'll find the best results from the OEM Hyundai filters which can be bought for cheap straight from the dealer. Alternately I use the Wix filters which I am also very happy with. It sounds like you're using a Fram filter, and those are among the worst to run in a Hyundai. Those cause severe ticking on my Accent and I've heard the same from several other people.
I've also found that Royal Purple 10w30 synthetic oil gives me good results. I tried running a couple other synthetics and synthetic blends but they always ticked worse than dino oil. I've heard Amsoil works well also but I've never run it myself. Pretty much any dino 10w30 worked for me with OEM Hyundai filters.
Definitely sounds like your HLA's, or your running low oil pressure in general. When you get the ticking, and then it stops afte revving, check your oil dipstick and make sure you're not low. If it is, then chances are your car is burning some, and you're running low. It could also be a faulty oil pump too, but chances are minimum for that to happen.
I've used nothing but Mobil 1 full synthetic since the very first day of owning the car. And I'm a freak...I change my oil every 2500 miles religiously, other than in the winter. I change it before I put it away for hibernation, and then again the day I bring it out. I try not to run the car or start it up too much during the cold months, because I hate the fact that the oil sits in the engine for 4-5 months at a time when I store the car.
I think I am having the same problem you are. I went to a Vavoline place ( first time I ever paid to get my oil change besides going to the dealer) Now it seems like I have lost power and ticking. Before oil this oil change I could hit 50mph in 2nd gear just over 5000rpm now I'm lucky to get up to 45mph just under 6000rpm. I know sometimes I beat the hell out of my car.
Doesn't feel like the clutch, still have a slight tick, but I think the power issue was the gas cause I filled up the other day now have no problem getting up to speed, lol kinda starting to wish something would go wrong with the engine so I have a good reason to do a beta swap. Wife dosen't understand why I should swap out engines when Mine only has 54k on it LOL.
QUOTE(187sks @ Apr 22 2009, 05:01 AM)
I have a weak HLA from when I ran 0W30 synthetic several years ago (don't ask).
Floyd is dead on (don't have any experience with Wix though). OEM Hyundai filters are key to maintaining proper oil pressure to keep the lash adjusters from tapping. My head started leaking last year, I have to put a half quart in every 2 weeks, so I stopped buying the expensive oil. Just straight up, cheap 10W30. I'm averaging 700 miles a week, changing the oil around 6000 miles... (I can notice when the oil starts to "break down" when the ticks start coming).
Sidenote: Just rolled 225K... I'm going to hit a quarter million miles easily...
