Oil catch can install
Old Sep 30, 2008 | 10:10 PM
jsharptooth91's Avatar
Vehicle: 2002 Accent 2.0L
Default Oil catch can install
I'm a little confused on how to hook up a catch can. Hopefully some one can clear it up.
I can find diy on the subject, I'm confused on where to hook up the lines to.
I know you hook up one line to the PVC. (Do you tee into that)?
Where does the other line plug into, on the intake or the valve next to the PCV <--- don't know the name of the valve!
Thanks in advance.
Old Sep 30, 2008 | 10:27 PM
Valve cover vent tube to catch can to either atmosphere or intake tube. You can tee the valve cover vent tube and PCV tube together then off to the oil catch can if you want to. Gotta plug the place where the PCV goes into the IM though if you do that.
