door lock problem
Old Apr 24, 2003 | 04:23 AM
Slver01Tib's Avatar
Default door lock problem
Ok, i have that central door lock thing.(if thats what it is called-where you lock/unlock the drivers door the passenger does the same)
well if i try to unlock the passenger door on the outside with the key, it doesn't unlock. is that supposed to happen?
Old Apr 24, 2003 | 04:56 AM
#1. Make sure that the "lock-out" button is not pressed on the drivers side console.
#2. Turn the key the "other" way. The passenger side door lock is the reverse of the drivers side door, so you need to turn it the other way (at least on my car).
[ April 24, 2003, 12:40 PM: Message edited by: Random ]
Old Apr 24, 2003 | 08:10 AM
Slver01Tib's Avatar
turned key both ways....nothing.
looked for a "lock out" button. didn't see one except for the windows.
Old Apr 24, 2003 | 01:16 PM
turbulence's Avatar
1) can you unlock it from the toggle switch on the inside of the passenger door?
2) can you unlock it using the key on the driver's door?
3) can you unlock it from the toggle switch on the driver's door?
Old Apr 24, 2003 | 08:23 PM
da nam's Avatar
central locking is when you lock or unlock all doors from the drivers door (central)
[ April 25, 2003, 03:24 AM: Message edited by: da nam ]
Old Apr 26, 2003 | 04:18 AM
Josh's Avatar
Vehicle: 1997 Hyundai Tiburon FX - now 2006 Infiniti M35 Sport
The actuator on the passenger's side is activated by the driver's side, but it doesn't work the other way around.
What you are experiencing is the way it is designed, not a problem.
I hope this helps in avoiding some confusion.
Old Apr 26, 2003 | 04:24 AM
Slver01Tib's Avatar
so I am not supposed to be able to unlock the passenger door from outside?
Old Apr 26, 2003 | 03:56 PM
Josh's Avatar
Wait, do you have keyless entry?
If not, then you can unlock the passenger door from the outside, but it will not unlock the driver side. If you unlock the driver side, then both should unlock.
If you do have keyless entry and the passenger's side is not unlocking, then the actuator might have gone bad.
Old Apr 27, 2003 | 06:51 AM
alz99's Avatar
Vehicle: FX Coupe
hmm. so if my alarm won't unlock or lock my passenger side door it will be the actuator????
Is there any way you can you fix them?
[ April 27, 2003, 11:52 PM: Message edited by: alz99 ]
Old Apr 27, 2003 | 04:06 PM
Shadohh's Avatar
Slver01Tib:
This is a VERY COMMON Problem with tiburons. The tech at the dealer know about and know some tricks to get it to working.
It is a problem in all 97-01 tiburons.
Get use to it smile.gif even if hyundai fixes them they will crap out later.
Its just poor design in the wiring aspect.
Also ****ty quality door actuators.
