Torque specs?
Old Jan 7, 2003 | 02:25 AM
DynastyAccent's Avatar
Default Torque specs?
Okay, I'm replacing the gasket on my valve cover, and I'm trying to find the torque specs for the bolts holding it on. I looked on web-tech, and it doesn't say anything about the valve cover, unless they call it something else. Anyone have any ideas?
Old Jan 7, 2003 | 04:29 AM
turbulence's Avatar
ok, got it. the head cover needs 6-7 lb-ft. this is what you're calling the valve cover. the center cover, the thing that says "dohc 16v" needs 6-7 lb-ft, also. these figures are from my shop manual. hope this helps!
