Window Switch Circuit Board
Old Mar 11, 2003 | 12:45 AM
AllBlackTibby's Avatar
Default Window Switch Circuit Board
Well, I have changed the LEDs in my driver side window switch one too many times. I ended up breaking off a little piece of the conductive material on the circuit board, and now the passenger window button on the drivers side switch won't light up. Anyone have any ideas on how I can make a good connection? A while back I used to have some conductive adhesive paint, but I don't remember where I got that from.
Does anyone have an extra circuit board for an 01 Tib, drivers side panel or know where there is one at a junk yard? I will pay anyone who has an extra in excellent shape, or anyone who can get one. I tried all the junkyards around here, nobody has a Tib.
[ March 11, 2003, 07:47 AM: Message edited by: AllBlackTibby ]
Old Mar 11, 2003 | 12:56 AM
Skitzo's Avatar
Solder yourself a jumper from a piece of wire. Should work.
Old Mar 11, 2003 | 02:03 AM
DUH!!!
Sometimes you just overlook the most obvious solution. I actually kinda did that with a large piece of solder, but it appears as though it is failing. I will do what you recommend as a temp solution, but I would prefer something a little more sturdy than a wire jumper. I used that adhesive paint to fix my rear window defogger strip on my Cobra, I just can't remember what it was called or where I got it from.
Old Mar 11, 2003 | 06:17 AM
Hey tib, if that doesn't work, let me know. I can give you an extra switch assy I've got when I get back in July.
