TPS blues
Old Feb 27, 2003 | 12:22 PM
MadElantra's Avatar
Vehicle: 00 elantra
Default TPS blues
I started having the acceleration problems that were all to common so I replaced the TPS. Well a month after that, the problem returned. Its not as bad as the first time but its still there. Right now I don't care about it, but I will when I put my turbo kit in. Should I just keeping popping them in like they were going out of style, or look else where?
Old Feb 27, 2003 | 12:32 PM
Sir Moof's Avatar
Ok, the problem you're having, does it follow these symptoms?
1. Rough idle?
2. After you let off the gas pedal while in motion, the car gives a little jerk after a few seconds?
Old Feb 27, 2003 | 07:12 PM
MadElantra's Avatar
Vehicle: 00 elantra
The problem I'm having is when stomping on the gas, so to speak, the car hesitates with a jerky motion. Its only when I start to accelerate hard, other wise its fine.
: My idle does go up and down about 100 RPM but I think thats just due to bad intake flow.
[ February 28, 2003, 02:15 AM: Message edited by: MadElantra ]
Old Feb 28, 2003 | 01:24 AM
Enforcer's Avatar
MadElantra./.i have a tiburon which is auto and i had the SAME EXACT problem. it kinda is like when you stomp on the gas it hesitates for a split second..well i fcahnged my tps and the problem went away for a while. then i changed my plugs..and haven't had the problem in 2 months
Old Mar 11, 2003 | 11:54 AM
MadElantra's Avatar
Vehicle: 00 elantra
I replaced my TPS again but it got worse. I'm thinking its my bad custom intake setup. I'll just suffer till I get my turbo kit. frown
