Intercooler Sensor
Old Mar 9, 2003 | 01:52 AM
VALKYRIE YB70's Avatar
Default Intercooler Sensor
I am installing the intercooler from a `93 Mitsubishi Shogun / Pajero in my Scoupe Turbo...
(front of rad. mounted).
This intercooler was originally fan-equipped & there is an internal sensor fitted to it, which I can only suppose, is there to switch on the fan when the charge-temperature reaches a certain level.
The sensor has a 2-wire output & my question is, can this be used to drive any useful dashboard gauge, such as charge-temperature, or would it just be a sort of bi-metal strip on/off switch.
Nobody At Mitsu. U.K. is able to help & one of their garages said they thought it read boost!.
Any help gratefully received!.
Old Mar 10, 2003 | 04:12 AM
turbulence's Avatar
if nobody here has an answer for you, my advice would be to find a mitsu board and ask there. i've done this before, and people are ususally friendly to owners of other cars that ask questions like that.
Old Mar 10, 2003 | 05:38 AM
If the external is solid metal, it is a temp sensor. If the external has plastic on it, with a small hole, it is probably a pressure sensor (boost).
If you can remove the sensor, you can test it.
Put it in hot water and measure the resistance across the 2 wires. If the resistance Increases or decreases as water temp goes up...then you know you have a temp sensor.
If it is mounted IN the intercooler, I would put money on a temp sensor, not a Pressure sensor.
Old Mar 10, 2003 | 11:28 PM
Thanks very much guys!
