HEADER INSTALL ASAP!!!!!!!!!
Old Dec 31, 2002 | 02:41 AM
Viper966's Avatar
Default HEADER INSTALL ASAP!!!!!!!!!
i have the 1 piece 4-2-1 headers... how do i get the damn things in the engine bay... i cant get em up from underneath cuz either the alternator or oil filter hit it...
and i cant drop em in from above cuz the angle is 2 steep and they hit the top of the engine...
any suggestions... ive gotten 2 that point where im about 2 remove the radiator 2 get em in!!!
Old Dec 31, 2002 | 02:50 AM
If you remove anything, remove the alternator and oil filter. Just plug a rag or cap over the oil filter mount/drain hole.
It is a BITCH, but you bring them up from underneath. It took me about 15 tries to get Jaws021's HVE headers in/out...and that was without the alternator and oil filter.
Old Dec 31, 2002 | 03:07 AM
Viper966's Avatar
when i put the alternator back on how do i go about setting the belt tension... and i have to drain all my oil now dont i? god damnt
can i take the radiator out or will that now work? cuz i really dont feel like spending $$ on oil(just got it changed- mobil 1) when i can just reuse my coolant
Old Dec 31, 2002 | 03:09 AM
Viper966's Avatar
ok i got the tension thing.. i cant even finish up 2day.. its pouring outside and my garage has the rx-7's and 3 bikes in it sleeping for the winter
Old Dec 31, 2002 | 05:33 AM
Removing the oil filter won't drain out all of your oil. The majority of it is in the pan. You will only loose about 1-2 pints (half a quart) that's in the filter, and the stuff that is backed up waiting to get into the filter.
Old Jan 1, 2003 | 03:09 AM
Viper966's Avatar
ok what u have to do is just remove teh right radiator fan and take the top hose off ... than lift the radiator out a lil bit... and slide the headers in from the bottom... and u also obviously have 2 take off the PS pump
Old Jan 2, 2003 | 03:01 AM
long's Avatar
sorry to hear the prob's dude.
i left everything on my car. i just laid it sideways under the car then turned it and it went straigt up. except for a small metal tube.
