god damn my car lol
Old Nov 25, 2002 | 12:43 PM
tibboy316's Avatar
Default god damn my car lol
ok my idel sometimes is just fine when i start my car and if i drive it"nicely" but if i ride her hard to idel shoots up way high...
sometimes if i start the car my idel is eradic to start with
there is no CEL, so i think maybe cable is to tight or soemting
any clues
Old Nov 25, 2002 | 01:47 PM
ELANTRAVISION's Avatar
Don't expect a cold engine to run smoothly right after you start it up. Most idles flutter a bit when you start the car, but if its consistent it may be something you want to get looked at...
Old Nov 25, 2002 | 03:54 PM
D4Damager's Avatar
I always suggest full synthetic oil. Specially now in the winter it gets the oil circulated in your system a LOT faster then conventional oil. Even though this may not direct effect your problem, i'd look into it smile.gif
Mobil1 Synthetic is one of the better ones out there that you can get pretty much anywhere.
Lubrimoly, Redline, etc etc arent available anywhere near my place
Old Nov 26, 2002 | 04:10 AM
tibboy316's Avatar
one of my cabels is really tight and i adjsuted the screw on the back of tb. maybe one of these is set wrong now.
Old Nov 26, 2002 | 05:33 AM
moving to HELP forum.
Old Nov 26, 2002 | 05:42 AM
JAWS 021's Avatar
idle above 2000rpm is not normal
When cold it shouldint go higher than 1200rpm
Have you messed with your TB before? maybe when you removed your intake manifold to drill the holes for your direct port? wink
i would say TPS first...
Did you get your direct port setup working or the NX wet kit?
Old Nov 27, 2002 | 01:45 PM
tibboy316's Avatar
i gotit figured out...forsome reason my thorttle cable cameoutof itsslevvething tothe left side of the car. so thats all fixed. i took thenitrous out i got sick of it.
