CEL
Old Dec 5, 2002 | 08:44 AM
Relic's Avatar
Default CEL
My CEL is on and the codes i pulled were 0302 which they say is misfires detected on cyl.2. Checked ignition and plugs and just replaced fuel filter and Fuel Pressure Regulator. My only thoughts are bad fuel injector, bad piston ring, or valve gone bad. Rides very rough at take off and smoothes out and higher RPMs. Also has a sound like an exhaust leak but dealer said all sensors working fine.
Old Dec 5, 2002 | 08:59 AM
can you list your mods?
A bad spark plug wire, or bad plug could be the cause, as could a bad fuel injector.
[ December 05, 2002, 03:59 PM: Message edited by: Random ]
Old Dec 5, 2002 | 09:14 AM
Relic's Avatar
New breather filter to replace stock intake setup. larger TB. BIM and ceramic coated inside.
engine mods thats it. Checked plugs and none are fouled. MIGHT be wire but more likely im thinking the injector is clogged or bad. Used cleaner but only minor change. More driveability but still running poorly.
