car no starty??
Old Apr 6, 2003 | 12:24 AM
sharpshooter's Avatar
Default car no starty??
Ok clutch and flywheel are in everythings going good then wheel bearing goes ok fine fixed under warranty everything better. NOW today and yesterday when i go and try to start the car all i get is an extreamly fast clicking sound. Like its trying to do something but cant. If any one can help with this that would be great i dont wanna tow it to the dealer again this week. Thanks
Old Apr 6, 2003 | 01:11 AM
Max_Kool's Avatar
sound like the starter?
Old Apr 6, 2003 | 03:53 AM
sounds like your battery is dead, and doesn't have the juice to turn the starter/car over.
If you have access to a multi-meter, check the battery voltage at the battery while someone is trying to start the car. If it drops down to 10V or lower, your battery is the problem.
If you don't have access to a multi-meter, jump the car with jumper cables and another car and see if it will start. I'm betting that it will.
Old Apr 6, 2003 | 05:57 AM
well i got it started this morning but there was a bad rattle coming from under the engine area so i killed the motor and had it towed back up to the dealership gonna have them check the starter on monday. Since it was removed for install of clutch im thinking that might be the problem.
Old Apr 7, 2003 | 08:25 PM
sounds like your starter isn't engaging the teeth of the flywheel properly.
Old Apr 8, 2003 | 02:27 PM
Viper966's Avatar
yea i was gonna say, if they had the tranny off they coulda messed up the starter/flywheel mating if they resurfaced ur flywheel as well moon
Old Apr 8, 2003 | 02:46 PM
Well feeling a little salty but whatever. The reason it wouldnt start is my friend didnt tighten battery cables. suicide But the noise i mentiond just happend to be the output shaft bearing in the tranny going so it will be in the shop again getting that fixed so far this warranty thing has worked out and i really cannot complain to much. For now
Old Apr 8, 2003 | 09:13 PM
turbulence's Avatar
since you have the tranny off, it's time to pick up a phat clutch and fidanza flywheel.
Old Apr 9, 2003 | 01:29 AM
Just had the clutch and flywheel put in 2 weeks ago. (clutchmasters and fidanza) thats what started string of problems lol.
