all fixed then not
Old Jan 1, 2003 | 03:47 AM
Relic's Avatar
Default all fixed then not
Well we just got my car back running normal again. However i have one small problem. Before i tear it apart again and go looking i just want to hear some ideas. When i start my car and its a cold start it will start fine and idle fine and even reverse fine(backing out of the driveway), but when i put it in first and try to take off it will sometimes feel like its gonna go and then it feels like im getting slammed stop.(all brakes are off and i didn't suddenly become an idiot who is hitting the brake accidentally) It will do this for a second or two and then once the gas gets moving i guess it will run normally. Very annoying and it could be the stupid tps. The TPS i got with my new TB was bad and i never knew it. When i found out i put on the TPS from my stock TB and for a while now its been working fine. God forbid another TPS has gone out on me.(however i have a zefiro hood and it rains alot )
Old Jan 2, 2003 | 11:38 PM
I would check the vacuum line running to the fuel pressure regulator, and also your plug wires.
If you "floor" the throttle in neutural, does it hesitate before accelerating the engine?
Old Jan 4, 2003 | 03:11 AM
Relic's Avatar
only happens rarely and when i put it in neutral it was fine. One time i didnt notice it at first and it happened BAD when i shifted to 2nd
