wheel bearing
Old Apr 9, 2003 | 12:07 PM
turbulence's Avatar
Default wheel bearing
this is relevant to my previous post...
http://www.hyundaiaftermarket.com/noncgi/u...c;f=29;t=001001
two of the noises in said post (the noise of my muffler dragging and the oscillating squeak) happened AFTER i got the new rims and immediately during the first driving cycle (like the first 100ft), right after i jacked up the driver's side of the car to look at my fuel filter. could putting all that weight on the two passenger's side 40-series tires have messed up a wheel bearing? like, because there is so little sidewall to "absorb" the weight, could that have stressed the wheel bearing too much? i've jacked up just one side of the car countless times with the stock 195/55 tires on there, and this never happened.
Old Apr 9, 2003 | 02:17 PM
arn's Avatar
arn
bearings just go whenever. I have 205/40/17 tires and havne't had any problems. I'ved had them for about 20000 miles already and I had suspension upgrade which made it stiffer...
Old Apr 10, 2003 | 02:34 PM
Hyundai seems to have a problem with wheel bearings. It seems about 30% of our members have had at least one go bad, some have had the same one go bad multiple times.
Old Apr 10, 2003 | 10:17 PM
bryfx's Avatar
i've lost count
Old Apr 16, 2003 | 10:20 AM
Viper966's Avatar
guess what im going 2 talk 2 the dealer about 2morrow? yeap wheel bearings
Old Apr 16, 2003 | 11:35 PM
ONLY1DB's Avatar
mine went at about 94000 i'm guessing it was just basic wear and tear. a real PITA to install though!! i had to sent mine to a machine shop!! they were too rusted to get out!!
Old Apr 17, 2003 | 04:18 AM
Shadohh's Avatar
MY car stills runs strong, surprisingly...all the problems with my car are created by myself and after market parts.
no wheel bearing problems
off_topi off_topi
Old Nov 18, 2007 | 08:42 AM
lilfonzy's Avatar
Vehicle: 2000/hyundai/tiburon
got my tib new in 2000, wheel bearings went 2 months later, its time for a new one again this makes #7
does anyone know if puting in aftermart bearings like SKF bearing will last any longer?
Old Nov 19, 2007 | 10:28 AM
Dont know too many people that have ever used aftermarket bearings so cant help ya there. But if you're handy with tools and know how to change them yourself, just buy OEM ones (they're very cheap), go to a machine shop and have them pressed in, and you're good to go. smile.gif
