How do I mount the stick shifter???
Old Jan 31, 2003 | 07:09 AM
FlyRyde's Avatar
Default How do I mount the stick shifter???
Hey anyone with this swap experience should know this. I checked and the threaded holes where the selector was don't match up with the holes on the stick shifter. Are they suppost to???
Old Jan 31, 2003 | 07:40 AM
they don't line up. You'll have to drill new holes and weld on new nuts or thread the holes in some way, or just use bolts/nuts.
Old Jan 31, 2003 | 08:16 AM
Shadohh's Avatar
The backs one will line up.
The front 2 needs to be drilled and tapped
Old Jan 31, 2003 | 08:56 AM
FlyRyde's Avatar
Will is sit correctly. It looks like it might be sitting a little slanted?
Old Jan 31, 2003 | 02:50 PM
turbulence's Avatar
it'll sit fine. like shadohh said, the back two line up, the front two need to be drilled. i just used nuts/bolts and it works very well.
[ January 31, 2003, 09:50 PM: Message edited by: turbulence ]
Old Feb 1, 2003 | 08:31 AM
Shadohh's Avatar
Its fits perfect for me.
Old Feb 1, 2003 | 05:27 PM
FlyRyde's Avatar
I drilled and tapped and bought some metric bolts now even with the gap that b!tch is tight!
