s-afc air flow % question
Old Nov 14, 2002 | 02:26 PM
turbulence's Avatar
Default s-afc air flow % question
ok, so i have the s-afc installed. i had it display the air flow %. at wot, it only displayed approx 45-50%. does this mean that with my current bolt-ons, i'm only using 50% of the airflow that my MAF will sense? or that there is something wrong? i'm directing this towards random, red, shadohh, jaws. basically, i can't take in anymore air the way my car is now. furthermore, my MAF can sense twice the airflow that i can currently intake, so i'm only registering 50% (i said that for the layman). conesquently and theoretically, if i had a turbo, and let's say i could double my intake air volume, then the s-afc would read 100% for the airflow %? i think i stated my question clearly enough. let me know if anyone needs more explication.
Old Nov 14, 2002 | 09:20 PM
Shadohh's Avatar
Well, your wont suck in the full amount of air the MAFS can read, at WOT in 1-2-3.
You see it higher, Say you are in frouth going 5k-6krpms at WOT. You will see more air flow.
You engine just is not sucking in all the air possible. I think I read 64%-75% in frouth at WOT.
Old Nov 15, 2002 | 12:26 PM
Yes, it is telling you are only reading 50% of the MAF's capacity.
You really need forced induction to max out the maf.
Old Nov 17, 2002 | 04:33 PM
Machine's Avatar
I have one in my 97excel(accent)and ive always thought it was just that the settings werent really for my car and read incorrectly since its only a display which doesnt effect the output. Sort of good to know that there is that much tuning left in the sensor.
