- Steering
- Shifter install
- J2/RD Exhaust Camshaft On Intake Side Mod
- HLA Disassembly/Cleaning
- J2 1.8 ecu swap
- Beta2 transmission + shifter swap into J2/RD
- DIY: Remove/Replace RD Radiator
- DIY: Convert your Sonata (YF) LED Bumper Inserts from 2way to 3way mode
- auto to manual swap issues
- Does this kind of place exist?
- DIY Tint removal that actually works!
- thanks stocker
- Genesis Coupe DIY : Nexus 7 Tablet Install
- DIY: Forge Motorsport BOV install - Veloster Turbo
- DIY: Veloster/Veloster turbo spring install.
- Accent LC/LC2 Manual Trans Overhaul Manual
- Hello , HOW TO DO?
- The Foamectomy
- Getting rid of weather seal squeaks
- Genesis Coupe DIY Listing
- How to uninstall/install and clean/gap spark plugs (Genesis Coupe 2010-2012)
- Open Differential to LSD Swap (2010-2012 Genesis Coupe)
- DIY on boost gauge install
- HellBilly Garage Episode 1 - Genesis Coupe Front Bumper Removal
- Updated Car Maintenance Schedule Tables
- Re-dye leather with leatherique
- DIY: Solved! Car Won't Take Gasoline/Won't Fill Fast/Fills Slowly At Gas Pump
- DIY: How To Tell If Your RD Has ABS
- DIY: Remove/Re-Install Power Steering Pressure Hose
- Spark Plugs and Wires Replacement Help
- Keeping Track of Your Hyundai Vehicle Maintenance Records
- broken bolt
- Belt squealing
- x3 accent power steering delete
- Starter - 2000 Accent
- Adding load resistors to LED tail lights
- Diy: Front Lower Ball Joint Replacement
- Tighten Up The Sloppy Stock Shifter
- .25 Cent Mod Diy Soon
- Shark Wing Installation
- Programming a Remote?
- DIY tint removal
- Window Switch
- Automatic Transmission Service
- 2002 Accent rear bumper cover removal
- Painting Headlight Housing?
- Diy: Change Your Engine Oil (with Crankcase Flush)
- DIY: V6 Tiburon Headers
- Front Bumper And Driver Side Fender Replacement
- Diy: Alternator Bearings Removal & Replacement
- DIY: Genesis Intake silencer delete
- DIY: Red Out Tail lights
- Cv Joint Replacement
- 5-bolt Conversion
- DIY: LC/LC2 spring/strut replacement
- Diy: Five Lug Swap, GK -> RD
- HKS Turbo Timer Type I Installation Guide
- DIY: Slave Cylinder Mod
- DIY: Clutch Install (Beta Transmission)
- Low Temperature Thermostat
- 1.8 Cam Install Question About Tdc
- Short Throw Shifter 2001+ Accent
- Diy Rear Sway Bar Removal/replacement
- Moonroof Repair
- Strut Tower Brace Mod
- Diy Gauge Light Replacement
- Diy Painting Valve Cover
- Rd1 -> Rd2 Dash Conversion
- Cleaning The Maf
- Third Brake Light Diy
- Little Oops While Porting My Spare Intake
- Window Tint Laws
- Car Wont Take In Fuel At Gas Pump
- Tinting with VHT Nite Shades
- Diy: Ms-ii Extra Standalone Ecu
- 1.8 Intake Cam Problem
- HKS Turbo Timer Type II DIY Install for an RD Tib
- B&M shifter install guide for '97-'00 and some '01's.
- 2003 Elantra Remote Starter + Alarm Installation, Wiring Colors, + Notes of location
- LC2 Remote Starter + Alarm Installation, Wiring Colors, + Notes of location
- 00-05 Accent Radio Installation
- HOW-TO: Installing HEATED SEATS in 2001 LC
- Accent LC2 Mesh Grille Install
- Tach install on 2003-05 Accent
- HVE 20mm Accent Sway Bar Install
- Removing Accent Door Chime DIY
- HOW TO: Smoke your own Accent tail lights
- Accent 1.6l DOHC Evofusion header install
- Remove & Replace Elantra Front Turn Signal Housings
- Alternator Removal & Replacement
- Diy Replace Acceleration Sensor
- Diy: Replace Crankshaft Postition Sensor
- Diy: Replace Cam Position Sensor
- Diy: Replace Idle Speed Control Actuator
- Header Install Problem?
- Headlights
- How To Repair And Wiring Diagrams
- Diy: Throwout Bearing Removal
- Diy: Real Fog Light Mod For 97 Tibby
- DIY Hood Spacing
- DIY LC/LC2 to GK steering wheel swap.
- Diy: Independent Foglight Control
- O2 Sensor Related Cel Fix.
- HID's for the H11b's
- Diy Setting Engine & Camshaft (valve) Timing
- Diy Replace Oem Rubber Shift Linkage Bushings W/ Bearings
- Hardwire For Low Voltage Output (sat Radio)
- Diy Stop Seat Belt Latch Vibration
- DIY port matching + cleaning up the Stock IM
- Diy Repair Heater Switch Intermittant Contact.
- Accent LC beta swap DIY:
- Diy: Oem Bumper Mods
- Aftermarket Horn Wiring Issue
- Programming Keyless Entry for '01-'03 Elantras (GLS/GT/VE)
- Request: Adding A/c
- Anyone Installed An Aftermarket Button For Their Horns?
- Diy Videos
- Diy: Header Install
- Diy: Changing Clutch Fluid
- Timing belt on a 03 hyundai accent?
- Diy Cv Removal
- Diy Remove Rattling And Exhaust Noise
- Diy Porting Stock Im
- 3 Turbo Choices To Choose For... Help Me Choose!
- Looking For Diy On Installing Hks Ssqv Into The Flange
- Looking For A Diy For Car Painting
- Diy Vin Decoder
- Touch Up Painting - Caliper Painting
- Oil Pan Removal
- Front Bumper Modifications, Cuda 2
- New Cd Player Q?s
- Diy: Packing And Shipping Parts
- Diy: Install Hood Lifters
- Removing Steering Wheel
- Diy: Polished Aluminum
- Diy: Make Your Headlights Brighter
- Diy: Polished Aluminum Shifter Ring Leds
- Diy Install High/low Halos
- Diy: Stop Low Beam Vibration
- Air Bags?
- Custom Bbk For Your Tiburon
- How To Remove The Clutch Release Bearing
- Optimoprime's Beta2 Engine Swap Thread
- Front Marker Light Mod
- How To Clean Your Car
- Bros Gagues Question
- Question for you visions
- Tiburon Electrical Schematics
- Cruise Control Install?
- Removing Chime When Keys Are In Ignition...
- Diy Replace Motor Torque Mounts
- How 2 Do The Captive Rotor Swap
- Fog Light Removal
- Drwg For 8 Bolt Shifter Rin
- Diy: Deglaze Clutch
- Diy: How To Search!
- Diy: Megasquirt Ecu
- Diy: Flasher Replacement
- Diy: Starter Button (version 2.0)
- Diy: Create Own Nitrous Setup
- Diy - Sea Foam
- Diy: 10 Easy Steps On Posting Images For Newbies.
- Memoirs Of A Boosthead
- Diy Change Axel Seal
- Diy Burnout
- Changing Your Tires
- Diy Mount Ath Roof Spoiler
- Diy Clean Your Pcv Oil Drain
- Removing Tailights On Rd2
- Diy. Aux Input For Your Headunit
- Diy = Checking Your Tps Model.
- Diy = Changing Fuel Filter
- Diy = Fuel Pump Test
- Diy = Meccatune Hid Kit
- Diy Timing Belt 2000 Tiburon Beta I
- Painting Dash And Side Panels
- Diy Rear Brake Pads
- Diy Install Nitrous Oxide - Zex
- How To Downshift
- Diy : Auto Transmission Cooler
- Replace Your Bad Wheel Bearing Yourself!
- Removing A Car Dent With An Airduster And Hairdryer.
- Knowledge Post: 1.8 Ecu
- Diy Changing Non-captive Wheel Bearings/hubs
- Total Stereo System Install
- Diy Silent Wirelooms
- Want To Design Your Own Gauges?
- Diy Fiberglassing In A Tib
- Diy = O2 Wire Harness Extensions
- Diy: EL gauges
- Ark Short Shifter Diy
- The New 1.8 Cam Install
- DIY Gk Tiburon Pedal Covers, Without Using Glue.
- Need To Convert Something?
- Diy: Window Regulator Replacement
- Diy Underdrive Pulley: RD Tib
- Injen Wai Install Without Battery Relocation
- Que?
- Diy Fiberglassing
- Led In Dimmer Switch Diy
- Led Headlight Adjustment Switch
- Fit A Overhead And Mod The Visors..
- Supercharger DIY?
- Complete Mirror Of Webtech
- Koyo Radiator Install- Direct Fit
- Diy Steering Wheel Removal And Aftermarket Install
- Painted Headlight Bezels: With Pics
- Clear Corners: Diy With Pics
- Feeding Cold Air To Cai.
- Underseat Led Diy
- Diy Tinted/clear Taillight Covers
- Upgrade To A Oem 12" Bbk!
- Diy 3rd Brakelight
- Diy Double Din Install
- Diy Racing Seat Fitting
- Diy: Timing Belt Change
- Diy: *video* How To Change The Oil On Your Rd1 Or 2. *56k No*
- Diy - Led License Plate Lights
- Diy Catch Can W/ Strut Bar
- Diy: Dancing Leds.
- Diy: Rd2 Hvac Knobs In Rd1 Dash
- Diy Chrome Paint
- Amplifier Wiring ยป From Engine Bay To Boot
- Diy: Cheap Arse Rear Strut Bar
- Quick & Easy Rim Restore
- Elantra Hatch Rear Fogs
- Diy: How To Pack And Ship Large Items
- Diy: Change Struts
- DIY's from other sites
- Ultimate DIY
- Diy : Captive Hub/rotor Swap.
- Diy: Jack Up Your Car
- Diy Pix For Leds In Heater And Tibby01's Switch Mod
- Diy: Cleaning Your Aem Cai Filter
- Volvo V40 Washer Nozzles
- Create Your Own Navigation System.
- Diy: Washer Fluid Nozzle Relocation
- Diy: Auto Dimming Mirror Install
- Evaporation Cannister Relocation
- Alpha_male Interior Painting - Diy
- The Secret To Painting!
- Diy Turbo Manifold
- Diy - Halo Hid Headlight Setup
- Outlaw Engineering Phenolic Spacer Install
- Side-view Mirror Rattle Fix
- Easy Headlight Aiming
- Get Rid Of Window Rattle
- Gear Link Mod
- Diy Struts And Springs
