2003 Elantra Remote Starter + Alarm Installation, Wiring Colors, + Notes of location
Old Apr 29, 2009 | 07:47 AM
Default 2003 Elantra Remote Starter + Alarm Installation, Wiring Colors, + Notes of location
By f0rbidden
12volts red (x2)(common 40A) + ignition harness
Starter white + ignition harness
Second Starter N/A
Ignition red + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory red + ignition harness
Second Accessory yellow + ignition harness
Keysense green + ign harn or ETACM, 16 pin plg, pin 2
Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the A/C controls.
Power Lock yellow - dr kick or ETACM, 20 pin plg, pin 20
Power Unlock yellow/orange - dr kick or ETACM, 20 pin plg, pin 14
To unlock the driver door only, use blue (-) at the relay to the right of the fuse box, or at the ETACM, 16 pin plug, pin 1.
Lock Motor gray 5wi driver kick or door lock control mod
Notes: The door lock control module is in the center console, behind the A/C controls.
Unlock Motor yellow 5wi driver kick or relay R of fuse box
Parking Lights+ green/orange (L), pink ® + fuse box, blk 14 pin plg, pins 8, 14
Parking Lights- blue - switch or ETACM, 16 pin plug, pin 14
Hazards green (only w/fac. alarm) - ETACM, 12 pin plug, pin 8
Turn Signal(L) yellow/orange + turn signal switch
Turn Signal® blue + turn signal switch
Reverse Light brown + driver kick, 15 pin plug, pin 2
Door Trigger yellow - dr kick or ETACM, 20 pin plg, pin 18
Dome Supervision yellow - fusebox or ETACM, 20 pin plg, pin 11
Trunk/Hatch Pin green to green/black - dr kick or ETACM, 20 pin plg, pin 10
Hood Pin green/black - pin sw or ETACM, 12 pin plug, pin 7
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock with ign, acc, and key sense
Tachometer blue ac PCM, 81 pin plug, pin 66 or cluster
Notes: The PCM (Powertrain Control Module) is above the driver kick panel.
Can also go to any fuel injector and use the wire that is NOT white.
Wait to start N/A
Brake Wire white + brake pedal switch or driver kick
Parking Brake blue - parking brake switch or driver kick
Horn Trigger red - horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Not Available
