2003 Elantra Remote Starter + Alarm Installation, Wiring Colors, + Notes of location
By f0rbidden
12volts red (x2)(common 40A) + ignition harness Starter white + ignition harness Second Starter N/A Ignition red + ignition harness Second Ignition N/A Third Ignition N/A Accessory red + ignition harness Second Accessory yellow + ignition harness Keysense green + ign harn or ETACM, 16 pin plg, pin 2 Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the A/C controls. Power Lock yellow - dr kick or ETACM, 20 pin plg, pin 20 Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the A/C controls. Power Unlock yellow/orange - dr kick or ETACM, 20 pin plg, pin 14 Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the A/C controls. To unlock the driver door only, use blue (-) at the relay to the right of the fuse box, or at the ETACM, 16 pin plug, pin 1. Lock Motor gray 5wi driver kick or door lock control mod Notes: The door lock control module is in the center console, behind the A/C controls. Unlock Motor yellow 5wi driver kick or relay R of fuse box Parking Lights+ green/orange (L), pink ® + fuse box, blk 14 pin plg, pins 8, 14 Parking Lights- blue - switch or ETACM, 16 pin plug, pin 14 Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the A/C controls. Hazards green (only w/fac. alarm) - ETACM, 12 pin plug, pin 8 Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the A/C controls. Turn Signal(L) yellow/orange + turn signal switch Turn Signal® blue + turn signal switch Reverse Light brown + driver kick, 15 pin plug, pin 2 Door Trigger yellow - dr kick or ETACM, 20 pin plg, pin 18 Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the A/C controls. Dome Supervision yellow - fusebox or ETACM, 20 pin plg, pin 11 Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the A/C controls. Trunk/Hatch Pin green to green/black - dr kick or ETACM, 20 pin plg, pin 10 Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the A/C controls. Hood Pin green/black - pin sw or ETACM, 12 pin plug, pin 7 Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the A/C controls. Trunk/Hatch Release N/A Power Sliding Door N/A Factory Alarm Arm factory remote only Factory Alarm Disarm factory remote only Disarm No Unlock with ign, acc, and key sense Tachometer blue ac PCM, 81 pin plug, pin 66 or cluster Notes: The PCM (Powertrain Control Module) is above the driver kick panel. Can also go to any fuel injector and use the wire that is NOT white. Wait to start N/A Brake Wire white + brake pedal switch or driver kick Parking Brake blue - parking brake switch or driver kick Horn Trigger red - horn switch Memory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Immobilizer Bypass Module: Not Available |
