Short Throw Shifter 2001+ Accent
Old Aug 27, 2009 | 02:54 PM
03AccentVA's Avatar
Vehicle: 2003 Hyundai Accent
Default Short Throw Shifter 2001+ Accent
I don't know if this applies to all Accents but it worked for my 03.
Credit to TWMPerformance.com
DIY
Also I found it extremly hard to remove and reinstall the clip in step 7.
What I did to remove it was start with a small precision screwdriver and step up to a full size flathead as you get each size wedged in. I used three "step ups" (precision->small flat->normal flat) If you have a dremmel use that instead.
To reinstall I used a 13mm socket and a 6in c-clamp: Put the clip on the open end of the socket and have someone hold that in place while you tighten the c-clamp on the whole assembly.
Old Aug 27, 2009 | 08:39 PM
bdiggy's Avatar
That was also the biggest pain in the ass step for the Elantra install. That little clip sucked! Other than that, a really straight forward install and TWM's instructions are great.
Old Aug 27, 2009 | 09:25 PM
03-accent-03's Avatar
Vehicle: 03 Hyundai Accent
I worked forever to get that fucking clip off and then I found out I could have cut it off because it came with a new one. AAARRRRGGGHHH!!!
Old Aug 27, 2009 | 09:34 PM
bdiggy's Avatar
^Haha, yeah, that and they're really cheap to pick up a couple of spares. Still a pain though. you have to work it out far enough away from the shifter cage to get a cutter on it first.
Old Aug 30, 2009 | 06:18 PM
03AccentVA's Avatar
I've bben driving with it for a few days now and I love it! The only issue I have is that the cup holders are now useless, cause when they're out the shifter rests right on them in frist, third, and fifth gear.
I bought some of thoe window cup holders from wal-mart so I just have to get used to using that instead.
