- Beta 6-speed transmission build
- Does beta 2 01-06 Elantra automatic transmission fit beta 1 auto?
- 5th gear syncro grind
- Changing Gears
- Differential ring gear gone
- Is being able to drive manual a lost art?
- Average lifespan of a factory clutch?
- Is there a way to monitor transmission temperature?
- Lightweight flywheel for Accents
- 5 things you should never do in a manual transmission
- GK 2.7 v6 outer cv axles on 2.0 I4 inners?
- Is my 03 Sonata transmission totally trashed?
- Short shifters
- Polyurethane transmission mount
- Anyone else have a very noisy clutch when it's cold
- Quaife LSD
- Can only find an LSD for RD1's
- Transmission capabilities
- Is it good to take your engine up to redline
- Does holding the clutch in do anything bad?
- Need a new clutch
- SIII transmission
- Gear Ratio Dilemma for Boost
- Kaaz Differential
- Replace syncro or replace trans
- Dsm lsd 04 Tib trans
- Transmission swap wiring
- XD Shift Cable Bearing/Bushing Sizes?
- Power shifting
- 5 speed swap into x3
- Clutch Sticking To Floor
- Transmission Jacks
- Shifting Smoother
- transmission swaps for rd2
- Sh*t Guys Who Drive Stick Say
- Are SPEC clutches still junk?
- Clutchnet Clutches
- Clutch Suggestions
- 1000hp Axles for Tiburons/Elantras
- Clutch Masters Twin Disk Clutch Kit
- Push type conversion for GK V6 6spd?
- How much can I expect to pay to have my clutch replaced?
- Stainless Steel Clutch Line
- Clutch chattering when its cold
- Clutch fork issue
- Clutch pedal is easy to push in
- Do I Have a Bad Throwout Bearing or Pressure Plate?
- Looking for an LSD
- 99 Accent auto to manual swap
- Flex Discs
- drive shaft for
- Thread dimensions needed
- Stall converter?
- Rebuild trans or buy a new one?
- humming from trans?
- Fidanza Flywheel
- Kia Shows Off Dual-Clutch Gearbox, Mild Hybrid System at Geneva
- Maybe not all girls
- Manual/stick shift question
- Off Balance Flywheel
- Steel vs. Aluminum vs. Billet Steel flywheels
- Tiburon stuck in park
- Final drive options for beta 2.0 M5BF1
- Straight cut gears
- Skip shifting versus short shifting...
- 2014 Genesis To Go On Sale With HTRAC AWD System
- Clutch by wire?
- Unbreakeable manual transmission.
- Shifter Mod
- Funny transmission commercial
- M/T owners -- how do you drive in stop and go traffic
- Carbon Fiber Drifeshaft
- Why do driveshafts need to lock into gearbox?
- GK transmission question
- Are there any clutches from other cars that would fit ours?
- Can you fit a Beta Gearbox on Alpha Engine?
- Transmission Installation Trouble, Snap Ring Trouble, Please Help
- Did you take your drivers test in a manual?
- Tiburon compatible trans?
- Need answer to slave cylinder question as fast as possible please
- has anyone daily driven a twin disk clutch?
- dropping the trans
- cryo treating your 5 speed
- Hyaundi will not go into gear please help
- Prevent carjacking? Drive manual...
- 1st gear really hard to get into
- want to do auto to manual trans swap
- Bahnhof Stage 3 Clutch Kit? Ebay
- Transmission problem on gen coupes
- How many clutches have you been through?
- shifter base bushings and and rebuild kits.
- Im surprised modern cars dont have these
- best trans for all motor?
- Clutch SLIPPING
- Clutch Slip in Neutral?
- gear ratios
- Better to rebuild transmission or just buy a new one?
- what are the consequences of driving on a bad throwout bearing?
- VHR Clutch kit
- Gearboxs.. Power limits ? new years ? any better ?
- Not going into 4th all the way
- neutral coasting?
- odd oil question
- tiburon 4wd
- Odd noise when pushing the clutch in.
- Is it a clutch or clutch master cylinder problem?
- Double Checking Flywheel Question
- KFX Performance (Short Shifter & Megasquirt) Question
- clutchmaster clutches
- Shifting an auto while driving
- Clutch Options
- hard to get into 3rd from 2nd. But 4th To 3rd is fine.
- SHIFT LIKE A BAWS
- So were did this rumor start?
- Shifting, Revs, and Clutches
- Clutch Looks Good, Won't Go Into Gear, Lost Pedal Feel
- RHD gear selection
- Puck Clutches
- Raising redline
- quickest stock 5spd trans for a beta1
- Betaswap Driveshafted Required.
- Beta Drive line/Shaft Problem/Confused
- Odd downshifting operation
- How often do you chirp/bark going into second?
- If you broke your right arm
- overdrive issue?
- Syncros and Gears
- Quick questions for Quaife owners...
- POLL: How often do you shift smoothly?
- Just did the trans service with MT90
- Painting the transmission
- 1998 tiburon, automatic, occasional slipping,
- Lightweight Flyweel + OEM clutch
- Stiff clutch
- Clutchless shifting
- Tranny fluid for track cars
- Cold weather rev limiter
- Slipping clutch
- tob keeps going bad!!!!!!!!!!! wth??
- Bleeding the clutch after track days
- Close ratio transmissions
- 03 tranny 97 tranny
- Thoughts on a SS clutch line
- Reverse whine
- Explain to me how this shifter works
- Shifter bushings
- Hyundai, Kia to Unveil 10-Speed Transmission by 2014
- Who has broken a clutch fork?
- Is My Clutch Slipping?
- Shifting into neutral without the clutch
- M/T tranny owners – how often do you stall out?
- Does a CVT extend engine life?
- Flywheel resurfacing
- How much power can the stock genesis clutch take?
- Saving fuel with neutral?
- M/T Redline oil change intervals
- When revmatching is it better to be above or under specified RPM?
- Double clutching; is it necessary?
- When to shift from 2nd or third into first
- All the more reason to drive stick
- Who sells aftermarket shifter bushings now?
- Auto trans. electrical failure
- Any Redline product for automatic transmission (AT-90...????)
- Can transmission problems affect Dyno #'s?
- Manual transmission oil recommendations and discussion
- Clutch material. kevlar or organic?
- Fidanza Flywheel & the 1/4
- Adjusting Clutch
- ARP flywheel bolts question
- What kind of oil do I use for transmission?
- How does everyone hold their shifter?
- 2.0l Fidanza Flywheel!
- Painting my transmission?
- Manufacturerer of performance gearbox parts
- What RPM do you shift from 1st to 2nd?
- Question about clutch and flywheel
- F1 Racing flywheel
- looking for techniques to bleed worn slave cylinder
- a bad slave cylinder cause clutch noise probs??
- Beta 1 and 2 Clutches
- Hypoid Gears vs. Redline MT90?
- What makes extreme clutches bad to have in a daily driver?
- Gearing
- Starting to get some clutch chatter
- At what hp is it time for an lsd?
- tranny swap
- Does your wife or gf know how to drive a stick?
- Can you gravity bleed our clutches?
- Clutch release bearing stuck! help!
- gear box oil check plug
- 1997 tiburon shift control
- 99 tiburon Automatic Rebuild kits
- down shift rev match?
- Clutch help!!!
- 97 tiburon tranny
- Axles
- New Clutch Recommendations
- Push conversion and pics plus old clutch with shimmed insert
- Is FWD or RWD better for off road?
- Hitting the Redline. Is it bad?
- Do adjustable short throw shifters exist for our cars?
- Can I put a 1.8 flywheel on 2.0??
- Manual Transmission Rebuild Kits
- HD Clutch
- My clutch finally bit the dust
- Tiburon tranny swap question
- Cutting down the shifter
- 1st to 2nd Gear Grinding
- soft clutch pedal after new clutch
- short shifter hits shift plate
- 11 elantra manual
- cable speedo to electronic speedo
- Make Your Transmission Bulletproof!
- Clutch issues
- adjustable clutch pressure?
- Beta 1 to Beta 2 Tranny Replacement
- wow this is ridiculous. new clutch and she is still slipping
- How much power can the stock beta trannys take?
- F1 Racing Clutch?
- Any recommendation on a clutch?
- pennzoil synchromesh?
- i gotta put in another clutch but i gotta do it cheap
- Can someone PLEASE explain to me the point of double clutching??
- 5 speed for beta engine question
- Strengthening an auto
- Longer gears
- Help me figure out this noise from transmission
- flwheel options...
- Stock flywheel weight
- Double clutching?
- another 5spd swap question
- Auto trans problem - 96 rd coupe
- any members from south jersey or close by? ...tranny swap
- Cluthc noise
- 98 internals into a 03-08 box?
- beta box internals in a alpha box?
- beta gearbox in 03 accent?
- OEM clutch disc with Aftermarket pressure plate
- Those of you real aggressive clutches
- AWD RWD FWD
- Shifter Bushing?
- Leather gear knob
- Are Fidanzas the only flywheel available for us?
- Clutch break in period
- New clutch disc??
- 4th Gear Ratios
- Clutch Masters Clutches...
- has anyone successfully changed the gearing in their car?
- Tranny oil change intervals
- looking for a short shifter
