hard to get into 3rd from 2nd. But 4th To 3rd is fine.
Old Aug 2, 2012 | 12:27 AM
Antonyr123's Avatar
Vehicle: Hyundai Accent
Default hard to get into 3rd from 2nd. But 4th To 3rd is fine.
Hey i have hyundai accent with Beta swap.
I dont think its a gearbox problem im just wondering if its the the gear links. Anyone else have this problem after a beta swap ?
Old Aug 2, 2012 | 12:33 AM
wheel_of_steel's Avatar
You can adjust your shifter by moving it back and forth on the four slotted holes around the plastic base.
It also pays to check that the shifter bracket is bolted together, and bolted to the transmission properly. Your best bet is to have somebody else sit in the car, and shift for you. Then you can be in the engine bay and check out the selector arm to see what is up
Old Aug 2, 2012 | 06:22 AM
I don't know why people move/delete pictures they used for DIY postings but the text remains and might give you an idea: https://www.hyundaiaftermarket.org/f...page__p__79904
Old Aug 2, 2012 | 11:20 AM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
Did you reuse the alpha trans or go beta trans?
