Bleeding the clutch after track days
Old Feb 8, 2012 | 01:31 PM
accentblurr's Avatar
Vehicle: 2002 Accent
Default Bleeding the clutch after track days
Is it a necessity to bleed the clutch after heavy track or auto cross days, with fresh clutch fluid?
Old Feb 8, 2012 | 03:39 PM
01steve's Avatar
Vehicle: 2000 hyundai tiburon
i've heard of doing this to brakes before track days to get the most out of the fluid-...
clutch though??? i would kinda eyeball it to see if it turned colors signifying that it has boiled and drain/bleed as you need (heh rhymes).
maybe someone w/ actual track knowledge should shed some light on this.
Old Feb 8, 2012 | 05:59 PM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
Usually you have to bleed the clutch beacause o fhte extreme amounts of heat, can cause the brake fluid to boil and become less effecient.
Old Feb 8, 2012 | 06:37 PM
Red Raspberry's Avatar
Well if you clutch fluid is getting that hot you have other issues. It usually takes over 500F to cause boiling.
