2.0l Fidanza Flywheel!
Old Sep 11, 2011 | 04:42 PM
Rd1cuda's Avatar
Vehicle: 1999/hyundai/tiburon
Default 2.0l Fidanza Flywheel!
I have a question, hopfully someone can help! Is a 96-99 2.0l tiburon fidanza flywheel identical to a 99-04 2.0l tiburon fidanza flywheel? I know the 96-99 has a 41mm crank and the 99-04 has a 35mm crank. Besides that are they identical in every way? Reason I'm asking is that I have a 35mm crank fidanza flywheel and would like to machine it to a 41mm so, I could use it on my 99 tiburon that requires a 41mm crank fidanza flywheel. If not I might have to sell it then. Any answers would be appreciated.
Old Sep 11, 2011 | 08:22 PM
BetaRD2's Avatar
Vehicle: Tiburon 2001
i've seen it done before, you just need a competent machine shop to do the work
the only problem i see is that the machine shop will probably like to have the crank as well to make sure of the exact measurement and fitment so check first with them before you do anything, or if you have another crank laying around that would probably help alot cause i dont think you want to take yours out
Old Sep 11, 2011 | 09:13 PM
https://www.hyundaiaftermarket.org/f...75#entry541075
Old Sep 12, 2011 | 12:27 AM
Rd1cuda's Avatar
Thanks guys for your info! Its seems that I can machine the flywheel to fit a 41mm crank. And Stocker thanks for the diagram that helps alot.
Old Sep 12, 2011 | 06:21 AM
. . . and that, ladies and gentlemen, is why we're all here.
Old Feb 16, 2012 | 11:32 PM
97dsscobra's Avatar
Vehicle: accent
nice!!! i was goin to buy a the flywheel with the 35mm size nd just by searching a little before ordering i found out that 1.8beta motor have the older crank with the size of 41mm crank.. slap hands!!
