soft clutch pedal after new clutch
Old Feb 24, 2011 | 12:24 PM
mhurlbutjr's Avatar
Vehicle: 2001 Tibby
Default soft clutch pedal after new clutch
I had new new clutch installed and now the pedal is on the floor when it engages is there anyway to adjust this my old stock clutch engaged without having 2 b on the floor. The new clutch is a stage 1 clutch masters.
Old Feb 24, 2011 | 05:33 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
did you detach the slave cyl? If so did you bleed that system after?
Old Feb 24, 2011 | 06:36 PM
AtomicX's Avatar
When my clutch got installed, the pedal was extremly light, but it got better after about 3-5 days of use.
Old Feb 24, 2011 | 06:43 PM
mhurlbutjr's Avatar
Vehicle: 2001 Tibby
Had a shop install it guess I will give it a few days.
Old Feb 24, 2011 | 07:46 PM
ivanhoe's Avatar
Vehicle: 2001 Tiburon
Grab a buddy and bleed it a few times. Quick and painless, you will know if that's the problem in 5 minutes.
Old Mar 5, 2011 | 10:18 PM
krazytib's Avatar
My clutch pedal was so touchy after I had the clutch replaced. The slightest amount of pressure on the clutch pedal would cause the clutch to engage. Our cars allow you to adjust the clutch pedal engagement distance. Slide under your dash so you can look above your clutch pedal and you will see the adjustment nuts. Play around with it until you are happy with it.
For instructions log into hmaservice.com and search for CLUTCH PEDAL INSPECTION AND ADJUSTMENT.
HTH
