Double clutching; is it necessary?
Old Dec 13, 2011 | 01:43 PM
My2000tibby's Avatar
Vehicle: 2000 Tiburon
Default Double clutching; is it necessary?
There are SO many videos on YouTube about "double clutching" like a mad tyte rac3r y0 and it boggles my mind. Are there ANY positives from it?
Personally if I shift down and want to rev match, as I shift down, I blip the throttle. That's it.
Old Dec 13, 2011 | 01:46 PM
Cujo's Avatar
honestly I used to do it all the time in the elantra and accent... not so much in the MS3 but It doesn't hurt to do it.
Old Dec 13, 2011 | 03:32 PM
No benefit unless you like slower shifts. Or have no synchro gears.
Old Dec 13, 2011 | 07:24 PM
wheel_of_steel's Avatar
Okay, I do it for the sake of having better foot skills. Then if I DO need to drive a car with a crashbox, it won't be an issue. It is still good for the transmissions, it just means that you aren't wearing out your synchros.
Rev matching is fine though, that is all you need to do for smoothness.
