- Towing stuff with a Hyundai
- How often do you double clutch?
- Is an lsd needed on a fwd street car?
- Flat foot shifting
- Squeaky clutch pedal
- Has anyone experienced rev hang with their car?
- clutch bushings
- Shifter bushings
- Which Redline oil do I use?
- Are SPEC Clutches any good?
- Quick question about flywheels
- fx coupe gearbox swap
- is it supposed to be hard to shift (N-1 and 1-2) into gears?
- How do you shift?
- Accent Quaife LSD
- Please explain why is it SO HOT when girls know how to drive manual?!
- How did you first learn to drive a stick?
- push clutch
- From Pull to Push
- Questions about Heel-Toe Downshifting
- clutch kits
- Shift Knob
- 5 speed owners
- friend sent this to me
- how many miles on your original clutch?
- Auto trans service
- Fancy clutches
- clutch chatter
- READ swapping to beta tranny
- Toughen Up 1.6 Accent/getz Gearbox
- QUAIFE LSD
- 98 elantra auto tranny
- Post pics of your shift knob
- cutting the stock shifter
- Anyone using BG Syncro Shift II in there tranny?
- Mt-90, how long they last?
- parasitic drivetrain losses
- Trans Swap Question
- LSD
- Transmission Interchange
- tiburon clutch conversion kits
- Are shift kits good on tibs?
- Transmission Swap: Tucson ?
- SS clutchline
- short shifter for an 01 accent
- My clutch needs to be replaced
- Crank pullys on an accent?
- Accent X3 shifter issues
- Heheh... Knob...
- Alternative clutch break in procedure
- Clutch
- 5 speed HD problems
- Clutch carnage
- Replacing the WEAK Links
- Quaife or Kaaz
- 300hp Accent Tranny problems...
- Beta with Alpha trannie clutch......
- SPEC SY63A flywheel
- transmission swap help
- TWM short shifter
- Clutch Review Thread
- Random revving and 3rd gear grind
- RD transmission issues
- Fidanza flywheel/ Clutchmasters stage 2 clutch?
- Tranny Break Down
- More Than You Ever Wanted To Know About Clutches
- Gear ratios and speed calculation
- rpm question....auto tranny
- guys who have done the swap
- where can I get a high performance clutch???
- High performance clutch
- power shifting
- experience w/ tranny rebuild?
- Who has an aftermarket stage 2 or 3 clutch
- Crank Pulley and Tranny Swap
- Cooling an auto tranny for road racing?
- QUAIFE...i got a quaife..........
- 00-02 1.6L Torque Converter
- Random or anyone
- What happens when a good tranny goes bad. (56k users beware, lots of pics)
- unorthodox ultra? G clutch
- URGENT !!!!!!!!!! Aluminum Flywheels READ
- Clutch question!!
- Auto Tranny Question
- quick question about different gen trannies
- Question for people with stick
- where is the kick down servo switch at?
- Nitrous on an automatic
- Advice on PP&Clutch
- tranny rebuild and new clutch??
- Gearbox linkage / slack removal
- how much hp can a 01 tib tranny take
- WHICH PICTURE IS RIGHT ? OR IS ONE AN AUTOMATIC?
- 5TH GEAR SWITCH [WHAT]?
- Dumbass Newbie Questions (6-speed questions)
- Anyone knows about LSD from Rally Art?
- unorthodox
- SE-R Spec-v Limited-Slip will fit 03 Tiburon ?
- rpm/mph poll 5spd only
- 97 Tib 1.8 at
- Very happy man, a must read
- Ques about Preasure Plate
- eclipse gst/gsx clutch
- Delta V6 6pseed tranny useless?
- torque converter
- Redline MT90
- help with an auto tranny....
- phantom grip lsd
- gear oil
- New clutch
- Syncros
- drivetrain losses?
- Limited Slip for Automatics
- Beta 5 speed on Alpha Motor?
- Those done or have done a Transmission Swap for a BETA engine
- turbo + stock A/T =
- Fidanza Flywheel from KORE
- Kore Clutch Kits
- can someone explain to me how this works?
- how to f**k up your tranny...again :(
- steel braided clutch line
- Check this place out:
- Level10, TC work...
- Fidanza Flywheel
- Beta stock clutch for $102
- performance clutch
- HVE quick shifters
- k-spec gear ratios
- quaife differential
- gear oil...
- The difference between transmissions?
- Tranny Swap
- Clutch Freeplay
- Quick FlyWheel Ques....?
- Quaife VS Kaaz LSD
- accent clutch please
- anyone know how much LC trany cant take
- Clutches for Uk People
- how long will my clutch/tranny live?
- Can this be True?
- shift kit for automatics?
- Automatic Tranny
- FORUM ANNOUNCEMENT
- 2K1 Tibby Flywheel
- Improved Clutch Release Shaft Upper and Lower Bushings (Clutch Squeek)
- ACT clutch
- Clutch Suggestions??
- upgrade torque converter
- Lightened flywheel with turbo....good or bad??
- clutch problem????
- clutch/ignition sensor
- Tried Installing a Fidanza flywheel today...
- how to fix ss bushings...
- torque converter mod?
- Broken B&M shifter
- guess what came in the mail today!
- 1st gen tib gear changing
- LHD and RHD shift gates
- AWD conversions
- Flywheel Install $$
- Permanant Price Reduction On Fidanza Flywheels
- New Fidanza Fitment Info.!!!!
- Kaaz Diff
- Squeaky Clutch
- Sequential Shifter
- Home made 'short shifter'?
- i remeber seeing someting about 6 sd beta?
- New LSD available?
- What do you think of this?
- Short Shifter
- Clutch install questions
- auto to manual swap
- gear ratios
- Changing Transmission Fluid
- Hey Red..... fifth gear?
- ok, where can us pre 6/99 people get a flywheel?
- Question for cost of manual tranny
- Do i need a new clutch yet?
- What other clutch brands available.
- 2nd gear grind?
- 2003 tib 6 speed a SE-R tranny.
- jumping out of gear (auto)
- beta 6-speed
- After market clutches {Elantra}
- tranny swap
- tranny making noise
- Limited Slip Diff
- the all-elusive auto-to-manual swap
- gst clutch
- what clutch
- Advice or help
- problem with shitknob.....?
- Clutch Slip at high speeds
- BETA 5spd Gear Ratios
- Kore LSD, Stage 4 clutch, drag axles
- installed B&M Super Cooler....
- need B&M pics
- Fidanza Flywheel Fitment
- Who actually has a B & M shifter installed on their 2001+ Elantra? Got a question..
- Clutch advise needed
- What tranny?
- Want a semi-manual car ?
- shift kit for auto?
- need tranny help NOW!!!! PLEASE.
- Clutchmasters Stage 1 Clutch
- manual tranny fluid??
- Taller Gearing = more speed
- Changing tranny?
- People with Automatics.
- Shifttronic in a 2k tib
- Clutch
- updated talon shifter will work
- strength of auto tranny
- Flywheel HP and WHP adverage difference? Red or Random help.
- Any solution to Weak 5th gear in Transmission?
- Transmission of 1.6 beta n 1.8
- Finished Rebuilt Tranny
- Clutchmasters FX100 or KoRe Stage2?
- need a performance clutch????
- 2k1 tib b&m shifter questions
- SR short shifter question
- lightning a flywheel
- Auto Tranny Cooler
- clutchmasters clutch
- (starting to be) clutch issue....
- maybe my clutch sucks?
- slicks and axles
- New info on clutches
- automatic tranny
- All 5spd owners
- Heavy duty clutch
- Gear Box Question
- Short Shifter Comparison
- BUSTED SHIFTER
- transmission failure
- gEAR RATIOS ON AN AUTO?
- b & m short shifter broken
- hve Heavy Duty Clutch Kit
- ClutchMasters Stage 4 clutch
- Automatic tranny
- early 2000 to late 2000 trans diffrences
- RPW CLUTCH vs HVE CLUTCH
- OBX short shifter install guide
- Transmissions Suck
- short shifter installation...
- Automatic Tranny fluid
- parasitic drivetrain losses and their solutions? PT 2
- Fidanza Flywheel
