WHICH PICTURE IS RIGHT ? OR IS ONE AN AUTOMATIC?
Old Mar 28, 2003 | 10:15 AM
accent Sonata's Avatar
Default WHICH PICTURE IS RIGHT ? OR IS ONE AN AUTOMATIC?
check out these two pictures to locat a back up light switch , which one is right ,for a 1999 Huyndai Accent
[img]"C:My Documentsack up switch.gif"[/img]
Old Mar 28, 2003 | 11:30 AM
skierd's Avatar
Vehicle: 1997 accent L
LOL, you cant post pics from your hard drive. THey have to be uploaded to the internet someplace for us to see them.
Old Mar 28, 2003 | 12:31 PM
Try again for pics.
[ March 29, 2003, 10:11 AM: Message edited by: Random ]
Old Mar 29, 2003 | 12:18 AM
Shadohh's Avatar
pretty much the same spot on the tib wink
Old Mar 29, 2003 | 03:12 AM
they are both correct, one just does not show the engine mount bracket. the drawings are just from different angles.
[ March 29, 2003, 10:13 AM: Message edited by: Random ]
Old Mar 30, 2003 | 07:04 AM
Thanks for the Help. I think I found the switch under the battery box , Now to get the connector plug off without busting a clip or wire?? suicide suicide
Old Mar 30, 2003 | 02:43 PM
it is a pinch connector. You should be able to just pinch the connector and it will pull off. You should be able to see the pinch tab.
Old Mar 30, 2003 | 04:24 PM
With the actual switch, do you pinch the mating connector with you thumb and fore
finger or must you use pliers?
beat_dow
[ March 31, 2003, 12:55 AM: Message edited by: accent Sonata ]
Old Mar 31, 2003 | 05:00 PM
turbulence's Avatar
the pic you just posted is of the female connector. it should have a tab that once the male connector is in, there's a little piece of plastic that pops up in that tab. that's what you press on. it's not a particularly hard task, but sometime they can be frustrating. you'll know what i mean once you see it.
Old Apr 7, 2003 | 04:58 PM
Thanks for the information, now to go further ,[say the switch is bad, If I take it out is there a ball and spring inside the tranny , and is there any tightening procedure to set it back in or just snug tight and thats it? help
