gEAR RATIOS ON AN AUTO?
Old Jul 29, 2002 | 07:32 AM
BLADE's Avatar
Default gEAR RATIOS ON AN AUTO?
IS IT POSSIBLE TO ADJUST THEM AND HOW?
Old Jul 29, 2002 | 07:36 AM
Hootie's Avatar
BLADE:
1. Please do not use all caps.
2. Anything is possible but would it be worth the amount of money you would have to pay on the labor alone to take apart the tranny?
Old Jul 29, 2002 | 07:39 AM
BLADE's Avatar
Hmmm good point.
Old Jul 29, 2002 | 07:43 AM
Hootie's Avatar
BLADE:
Hmmm good point.
The A/T is a service tech's wet-dream when it comes to labor costs and nightmare when it comes to actually fixing it. I've seen one after it was taken apart and I didn't realize the amount of parts involved. Not to mention it's all computer controlled which even complicates things even more. If you really want a better A/T, contact Levelten Performance and inquire about a torque converter upgrade or total tranny rebuild. In the end it may cost less than trying to change the gear ratios.
Old Jul 29, 2002 | 02:41 PM
Jed118's Avatar
Vehicle: Hyundai Pony
Yeah,, they're not really gears in the traditional sense, more like bands and clutches, and godforsaken valve bodies... OUCH what a headache!
Old Jul 29, 2002 | 04:24 PM
MeetTheCreeper's Avatar
yea you can change you're final drive ratio but it's expensive... and remember, a side effect of messing with your final drive ratio will affect your miles per gallon and such. I don't know how dramatically and it might not even be noticable, but it might be something else to consider
Old Jul 29, 2002 | 06:52 PM
MechaniX_034's Avatar
Vehicle: Lancer Evo IX
Automatic transmission consists mainly of drive and driven plates, front pump and torque converter, controlled by the valve body and AT Computer. There is also a kickdown servo and pulse generator sensors to keep tabs on everything.
Changing the gear ratios is extremely expensive because it requires very tight tolerance machine work, and some custom fabrication. The aftermarket valve body and front pump will also be very expensive. Yes, the final drive ratio can be changed and a LSD introduced, but again, the labour costs would be incredible. Why not go for the cheaper, and warrantied Level-10 conversion, or complete AT rebuild if you want it to be reliable under extreme power applications? It makes a lot more sense. Especially the warranty part.
Old Jul 29, 2002 | 06:59 PM
Hootie's Avatar
NeCRoASiAN:
All that = one complicated piece of technology. If you want a more detailed explanation including pictures check out www.howthingswork.com and go to the automotive section. There you can search for A/T.
Old Jul 29, 2002 | 10:00 PM
Moving to the engine/tranny forum...
