00-02 1.6L Torque Converter
Old Apr 14, 2003 | 02:53 PM
QS's Avatar
QS
Default 00-02 1.6L Torque Converter
For hyundai accent....
Can someone please help me find the part number for this item.
Ive looked on www.hmaservice.com but it didnt help.
Old Apr 15, 2003 | 12:37 AM
HMASERVICE is not designed to give part numbers. They only reference part numbers when a new part superceeds an older part.
use THIS site to find parts.
Old Apr 10, 2008 | 05:49 PM
Fintile's Avatar
QUOTE(Random @ Apr 14 2003, 11:37 PM)
So was the torque converter ever found? What that do anyway?
Also are the 1.5 and 1.6 trannies the same? whats the difference?
Old Apr 10, 2008 | 11:57 PM
What's your question? What's a torque converter do? If so it's what you bolt to the flex plate to run an automatic tranny instead of a clutch. It's the part that lets you have your engine idling when sitting still in park without it killing your engine.
Old Apr 11, 2008 | 06:19 PM
Fintile's Avatar
What about the 1.5 and 1.6 trannies? They biult the same? arent they the same?
Old Apr 11, 2008 | 10:57 PM
They're close but not identical.
They take different clutches but you can go back or forth.
Old Apr 12, 2008 | 07:10 PM
Fintile's Avatar
QUOTE(187sks @ Apr 11 2008, 09:57 PM)
So indirectly a S-coupe Turbo pushing 250 whp as long as you have a clutch designed for it the trannie can handle it and so may a 1.6 trannie?
Old Apr 12, 2008 | 09:13 PM
Yeah. I mean obviously it will have less reliability but it'll probably take it. If you switch trannys go with the Spectra5 tranny it has a low final drive and has the typical Beta tranny strength.
Old Apr 12, 2008 | 11:29 PM
Fintile's Avatar
QUOTE(187sks @ Apr 12 2008, 08:13 PM)
You say to switch for the KIA spectra 5 speed?
Old Apr 14, 2008 | 12:45 AM
Yeah, Kia wanted the Spectra 5 to be quicker so they geared it lower instead of giving it more power. It's 5 speed will bolt to your engine but you'll need new mounts. If you want higher top speed look through the gear ratios of other Beta trannys. I would say wait until yours gives you trouble though. Turbo cars are not as hard on trannys as N/A cars of similar power output.
