00-02 1.6L Torque Converter
For hyundai accent....
Can someone please help me find the part number for this item. Ive looked on www.hmaservice.com but it didnt help. |
HMASERVICE is not designed to give part numbers. They only reference part numbers when a new part superceeds an older part.
use THIS site to find parts. |
<div class='quotetop'>QUOTE(Random @ Apr 14 2003, 11:37 PM) </div><div class='quotemain'>HMASERVICE is not designed to give part numbers. They only reference part numbers when a new part superceeds an older part.
use THIS site to find parts.</div> So was the torque converter ever found? What that do anyway? Also are the 1.5 and 1.6 trannies the same? whats the difference? |
What's your question? What's a torque converter do? If so it's what you bolt to the flex plate to run an automatic tranny instead of a clutch. It's the part that lets you have your engine idling when sitting still in park without it killing your engine.
What about the 1.5 and 1.6 trannies? They biult the same? arent they the same?
They're close but not identical.
They take different clutches but you can go back or forth. |
<div class='quotetop'>QUOTE(187sks @ Apr 11 2008, 09:57 PM) </div><div class='quotemain'>They're close but not identical.
They take different clutches but you can go back or forth.</div> So indirectly a S-coupe Turbo pushing 250 whp as long as you have a clutch designed for it the trannie can handle it and so may a 1.6 trannie? |
Yeah. I mean obviously it will have less reliability but it'll probably take it. If you switch trannys go with the Spectra5 tranny it has a low final drive and has the typical Beta tranny strength.
<div class='quotetop'>QUOTE(187sks @ Apr 12 2008, 08:13 PM) </div><div class='quotemain'>Yeah. I mean obviously it will have less reliability but it'll probably take it. If you switch trannys go with the <u>Spectra5 tranny</u> it has a low final drive and has the typical Beta tranny strength.</div>
You say to switch for the KIA spectra 5 speed? |
Yeah, Kia wanted the Spectra 5 to be quicker so they geared it lower instead of giving it more power. It's 5 speed will bolt to your engine but you'll need new mounts. If you want higher top speed look through the gear ratios of other Beta trannys. I would say wait until yours gives you trouble though. Turbo cars are not as hard on trannys as N/A cars of similar power output.
