2nd gear grind?
Old Nov 22, 2002 | 12:50 AM
tibby01's Avatar
Vehicle: 2001 Tiburon
Default 2nd gear grind?
I have a 01 Tiburon, my transmission is grinding when I shift into 2nd gear at higher rpms (4500-5500). What is the problem? What is actually the prime shift points, isnt around 5500-5800rpms?
Old Nov 22, 2002 | 12:54 AM
How many miles do you have on the car/clutch? And do you always shift at that RPM? Is it the stock clutch or an aftermarket one?
Old Nov 22, 2002 | 12:59 AM
tibby01's Avatar
Unfortunately I still have the stock clutch, I normally dont shift at those rpm's, only when needed. I have 44,000 miles on the car
Old Nov 22, 2002 | 01:53 AM
Shadohh's Avatar
Grinding on a HIGH RPM shift from 1-2nd? Thats normal bro!
All the BETA M/T do it.
I think Random said bleeding the clutch pedal help.
[ November 22, 2002, 08:54 AM: Message edited by: Shadohh ]
Old Nov 22, 2002 | 02:02 AM
Skitzo's Avatar
yup mine's done that since the second week i had it (2k1). I have just under 15k on it right now. I did change to Redline MT90 fluid, and that kept the grinds away for about a month...but now its back to the grind. When I change the fluid it was NASTY looking too...so much was suspended in the old fluid, I'm not sure there is any gear left...hehehe.
Old Nov 22, 2002 | 08:50 AM
lantraluvr's Avatar
Vehicle: 1999 Elantra
Ok, my tranny is grinding at third. What could be the prob?
Old Nov 22, 2002 | 09:22 AM
Shadohh's Avatar
3rd gear grind? Tranny rebuild with the new syncronizers.
Old Nov 22, 2002 | 10:28 AM
lantraluvr's Avatar
Damn... I knew it. Thanks for the info.
