Fidanza Flywheel
Old Jul 2, 2002 | 05:40 AM
KSpec's Avatar
Default Fidanza Flywheel
http://www.ptuning.com/html/Item-Desc.cfm?...delDesc=Tiburon
Anyone have one of these pretty 'lil things?
Old Jul 2, 2002 | 05:56 AM
JAWS 021's Avatar
the only people i know with a fidanza flywheel is me and HRD tiburon
He actually has his installed,... my flywheel will be installed in a couple of months along with my other toys.
Old Jul 2, 2002 | 05:57 AM
Shadohh's Avatar
HRD has one.
I may be buying his.
Old Jul 2, 2002 | 05:58 AM
JAWS 021's Avatar
why is he selling it? frown
Old Jul 2, 2002 | 07:58 AM
KSpec's Avatar
Oh good, so I won't be the lone guinea pig on this one...it looks super nice. I will try and get one, but damn...$350, I will have to do some real saving for that plus the install...sheesh.
Old Jul 2, 2002 | 08:30 AM
Denisst99's Avatar
BEWARE....they list it like it will fit
all 2.0 engine, but i'm almost sure earlier 2.0 had a different flywheel,same diameter but different crank snout,someone could confirm this,maybee Cheuk,Red or Random
Denis
Old Jul 2, 2002 | 09:43 AM
neal's Avatar
350 is actually a good price. One of SR's KOmpetitors sells theiR own and it is actually lightEr then the fedenza unit by .5 lb. It also has the 6 hole pattern. they have it on special for 400, but normally it's 440.
Old Jul 2, 2002 | 10:05 AM
Chris H's Avatar
Hyundai switched cranks starting with model year 2000 I believe.
One of of them is backwards compatible with an adapter but I forget which.
Try and bolt a 98 flywheel to a 2001 crankshaft and you'll destroy it.
Old Jul 2, 2002 | 12:14 PM
KSpec's Avatar
So this flywheel will not fit the 2000 model Tib?
Old Jul 2, 2002 | 12:19 PM
Shadohh's Avatar
JAWS 021:
He had to pull it out, cause as the time he installed it he put in a new clutch and it was a bad clutch. The flywheel needs resirfacing and so he just put the old clutch and flywheel in.
